Cell Phones Logo
shaquon Robinson Posted on Apr 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can you remove password from an iPhone 5 without using iTunes
Tafi Nami
Level 2:
Sergeant:
  • Expert 297 Answers
  • Posted on Jul 31, 2018
Tafi Nami
Expert
Level 2:
Sergeant:
Answers
297
Questions
0
Helped
183170
Points
886
Hey guys! Can someone please help me? My iPhone 6 Plus has suddenly started acting weird. I was about to unlock it and send some urgent messages, but it didn't work after many attempts, so it is disabled now. I use this iPhone for work, and it's very disturbing, as I am not able to unlock it and make any calls or send texts. My iPhone password is not working but I'm sure it is the correct password (I use it everyday), so I think my iPhone passcode changed itself. I have no idea what happened at all. Please help!
5 Related Answers
A
Anonymous
  • Posted on Jul 22, 2008
SOURCE: iphone and activesync via usb without Itunes
i have the same question!!!
Anonymous
  • Posted on Dec 14, 2008
SOURCE: synchronize contsct on iphone with outlook without itunes
i am able to synchronizey contacts from outlook to iphone through itunes but problem is some of contacts getting twice.? please any one can help out from this problem
Anonymous
  • 192 Answers
  • Posted on Apr 18, 2010
SOURCE: iphone won't connect with itunes without unlocking
The only way you can connect to itunes with the iphone is if it is unlocked
Here is how to unlock your phone
Anonymous
  • 82 Answers
  • Posted on May 08, 2010
  1. Plug iphone into computer
  2. Right click and press backup
  3. Put iPhone into DFU mode:
  4. Hold Shift and Click Restore, and browse to the correct firmware downloaded from http://www.felixbruns.de/iPod/firmware/
  5. The iPhone will be restored, allowing you to set new password, however any non-backed up items will be deleted
  6. Good luck and rate.
mobil master
Computer Repairing
  • 14641 Answers
  • Posted on Sep 06, 2012
SOURCE: how to reset password on iphone without itunes
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
2answers
HOW DO I OVERRIDE IPHONE PASSCODE
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
For more details, check: How to Reset Password on iPhone
I need to reset my password for brighthouse tv on my ipad
As for resetting iPad password, an easy way is to utilize iTunes. Just refer to below guide.
For more methods, check: How to Reset Password on iPhone
How do you by pass password on I pad ?
If you want to bypass password on iPad, you have to reset the password through iTunes/iCloud or the 3rd-party tools. Just follow below steps to do that.
I can remember my password on my apple 5 cell phone
If you forgot iPhone password, you have to reset the password through several steps. Just follow below instruction.
Reset my passcode
It's simple. If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
I forgot my password, and disabled my ipad mini , and need to get back into it
Password Error "The old password is incorrect"
Facing this problem, you have to reset the password on iPhone. There are different methods to reach this aim. Just check below steps.
Password to unlock phone
If you forgot the password and can't unlock iPhone, just follow below steps to fix it.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
