Honda 3000 Watt  Portable Generator Logo
A
Anonymous Posted on Apr 17, 2013
I have a 3500 watt Honda generator blowing black smoke smells electrical
2 Related Answers
Norman Al-Anbar
  • 630 Answers
  • Posted on Sep 24, 2009
SOURCE: i have a honda em3500 watt generator that runs
it could be the connectors need to be changed, when you open the front of the gen you will see a shaft with wires attached to it in both sides a small charcoal like peaces attached with a small wires each these connectors see if the are touching the shaft or not and how long they are if they not or too short that mean you need to replace them and you can get them from any please by looking at the manual and get the number for them and do search on the net or local store...However did you first reset all your brakes? let me know if that work and please remember to rate my service so I am able to continue provide quality service and improve on it with your help. God bless
robert wales
  • 4977 Answers
  • Posted on Oct 14, 2015
SOURCE: Why my honda xl125s produces black smoke and smell gasoline evrytime i rev up
its running rich or the plug is fouled or the plug wire or plug cap is high in resistance. you need an ohm meter to check resistance of wire and cap. the wire should be less than 5-7ohms and the cap less than 10ohms. the running rich you will have to check the carb out for dirt and old fuel varnish build up.
2answers
I have a 7500 w Black Max generator not producing power and it only has 6.2 hours on it.
This small amount is used to create an electromagnet. As the engine begins to turn this electromagnet, moving its electric field, through the stator windings, your generator will produce more power. However, if residual magnetism is lost, your generator will produce no power at startup.
Mar 15, 2022 • Garden
1helpful
2answers
I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can check.
All Power America APG3535CN, 2800 Running Watts/3500 ...
www.amazon.com/...Power...Generator/.../B000U0OJ...
Amazon.com, Inc.I then call All Power and am told to give them one more day to get this worked out ....There is no styrofoam enclosure or crate to protect it, the generator is simply ...
NIKOTA 3500 WATT GENERATOR - YouTube
? 0:58
https://www.youtube.com/watch?v=NEeu9Y-0_KM
Aug 27, 2011 - Uploaded by mamasboypowersports
NIKOTA 3500 WATT GENERATOR. ... Diagnosing A GeneratorThat Has No Power Output. - Duration: 3:03. TheDIYGuyDOTnet 117,263 views.
I have a nikota 3500 watt generator and I am not getting any ...
www.fixya.com/support/t26062098-nikota_3500_watt_generator_am_not
2 hours ago - I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can ...
Generator outputs low variable voltage, ideas for troubleshooting ...
www.smokstak.com > ... > Generators & Motors General Discussion
1984 honda big red smoking out the exhaust littel oil coming out tho also it has the wrong carb on it the carb come off a honda atc 200x
If it is black smoke, it could be running rich and the correct carb will fix that. If it is blue smoke, then it is burning oil.
3answers
My 3000 watt honda generator doesn't seem to put out the proper power
http://cdn.powerequipment.honda.com/pe/pdf/manuals/31ZT7601.pdf
I would check spark arrester and clean it and the muffler first.lt could be the inverter unit. If you have a meter determine the output voltage, and freq. You would need a scope to look at waveform the repair should be lest to a repair center. suggest you call Honda for more guidance.
You could spend a lot of money on maybe parts./
1helpful
2answers
Electric Water Heater blows fuse, but only every few years
Your residential water heater is not 9000 watts. Or it would blow the fuse every day and melt the wire. Instead, you have dual-element non-simultaneous 4500 watt water heater.
http://waterhatertimer.org/How-it-works.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Look at label for 'total connected watts'
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
25 amp breaker or fuse and 10 gauge wire is minimum acceptable for 4500 watt water heater.
http://waterheatertimer.org/Color-code-wire.html
Troubleshoot blowing breaker or fuse:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Why does it blow fuse once each year?? I don't know.
Fuses and breakers trip when overheating occurs on wire.
Each fuse or breaker is rated for heat, and over time, it will get hot and then cool and then get hot again ... this action weakens fuse or breaker.
To solve problem: install 3500 watt elements (and clean sediment out of tank). Wire will run cooler, and fuse will last longer. Whole fuse box will demand less power, and run cooler, and will last longer as a result. So there is less stress on electric service panel.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3500 watt element will heat water to same temperature, but takes longer. For example: 4500 watt heats 21 gallons per hour, while 3500 watt heats 17 gallons per hour.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
The generator kicked the breaker of and was smoking and smelled like electrical
What type of load (electrical) was hooked up to this generation?? If the surge voltage and current was exceeded above the generator maximum for any length of time. There problems, it could be the regulator, insulation burnt off the windings.
I am taking a guess here. Now, 7100 Watts is it typical surge wattage. This mean that the generator will deliver 7100 Watt (voltage times current) this is know as the power factor. The actual operating load would be 6800 Watts and I would even operator the generator at its peak wattage. Something in the neighborhood of 10--15% less the peak wattage. Therefore a good positive theatrical Wattage would be 5800 to 6350 operating wattage. Then this generator would run all day.
Just remember Ohm's Law. Current plays a big factor in loading of a generator while the operation voltage is at 120 AC Volts. Example: electric motor; Now electric motor when starting will pull three time its operation current. Operating current for a 1/2 HP AC motor is 6 amperes but start this electric motor will require 18 amperes. This is one reason why they starting capacitors on smaller electric motors. Larger three phase electric motor can literal stop a generator cold...in its tracks. It put such a large demand on the generator it stops the engine powering the generator. I have seen crankshaft break because the generator could handle the heavy current load.
Remember, any time you are running a small gas powered generator. All ways figure what the load and surge current load will be before hooking up any generator. Normally this is figured in VA (volt/amps). Wish you lock. GB...stewbison
I have an EB6500 that was sitting for a while. When I started it it ran fine then after 3 minutes the generator head smokes and you get that electronic smell,even without turning on the main breaker.
Is that all you ran it was the one time? Sounds like a mouse. Or bugs got in there and built a nest, something just burning off. Get the air gun on that thing and blow it out, then try it again, hopefully it is just dust and dirt piled up in there.
Honda generator runs great,voltage output is good but when load is applied motor cuts off. no breakers tripped or resets tripped?
check your load..the generator is carrying heavy weight when you are going to load a high wattage thats why its RPM will turn slowly and have the possiblity to stop it...It MUST be needed the the given wattage of the generator is greater than the load you apply.for example:when your generator's specification is 3500 watts,tehn the load you are going to apply is i watts to 3499 watts only..
30 volts coming out of generator
sounds to me like a grounding issue. I would check all my ground paths and look for poor connection or corroded contacts, broken or almost broken wires etc. Hope this helps :)
Top Honda Electrical Supplies Experts
vince
Paul Carew
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
