SOURCE: How do ichange the time on Panasonic KX-T7431??
MUST BE DONE FROM EXT.101
1.leave handset in the cradle
2.Press "Program" button
3.Dial *#1234 (star pound 1 2 3 4)
4.Press Sp-phone button 3 times
5.enter the correct hour on the dial (2 digits)
6.press the button (in the lcd window to advance to minutes)
7.enter the correct minutes
8.press auto dial/store button
9.pick up hand set/ hang up hand set.
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
SOURCE: english manual for Panasonic KX-TG1100CE cordless phone
You can downoad it from this link: http://phone.manualsonline.com/manuals/mfg/panasonic/kxtg1100ne_kxtg1102ne_kxtg1103ne.html or you can buy a copy from : http://www.cordless-phones.uk.com/cordless-phones/digital-cordless-phones/panasonic-kx-tg1100-phone
................................................sodeep
SOURCE: Panasonic KX TCD715 Cordless Phone user's guid
I have solved the problem by downloading the user manual for Panasonic KX TCD715 from this page.
Thanks for your help!
Greetings from an island in the Atlantic,
HelleP531
SOURCE: How do I change the time on a KX-T7730 phone?
Basically, there are 2 ways of programming the date
and time - the short way and the long way.
If you are using the KX-T7730 phone on a Panasonic
KX-Txx 308/824 system:
SHORT WAY:
From the Switcboard / Main telephone
( ext 101, 10 or 9 ) with the handset on the
cradle/hook:
1. Press PROGRAM 0
2. Enter Date and Time
( The format is: yymmdd,
1 to 7 1=Monday 2=Tuesday etc, hh:mm,
0 or 1 0=AM 1=PM ) see example
3. Press AUTO DIAL / STORE to save your changes
4. Press PROGRAM to exit program mode
EXAMPLE:
If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook:
1. Press PROGRAM * # followed by the system
password ( default is 1234).
2. Now press 000 and then SP-PHONE.
Enter the year.
3. Scroll to the month with the right scroll key
(located at the right bottom corner of the phone).
To change the month use the AUTO ANS / MUTE
button.
4. Now scroll right again and change the date and
day.
To change the day, again use AUTO ANS / MUTE
5. Scroll right again and the time will appear.
Set the time.
To change am/pm scroll to it, and again,
use the AUTO ANS / MUTE button.
6. Press PROGRAM to exit program mode and you
are done.
