Toshiba DKT3020SD Corded Phone Logo
Posted on Mar 11, 2009
Programming a Name in Toshiba DKT3020-SD
At my place of employment, we have Toshiba DKT3020-SD telephones. I need to know how I can change the name on the phone in my office to mine. It still says the girl who worked there before me. Any help?
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Mar 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7731
Points
9
To edit display name on LCD DKT3020-SD.
Follow this sequence:
Mode
Scroll
Enter passwork - 0000 is default
Hold
Hold (again)
DN ID (This is your phone extension #)
Old name should now be displayed. Hit page button to delete letters, scroll button for space.
Use characters for the the associated number key to enter desired name. For example if you want an "F" you would hit the 3 button 3 times. After your name is entered, press hold. Pick up and put down receiver.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6708
Points
To edit the name displayed on the LCD by your extension begin by entering edit mode
DN + #621
The following key sequences perform the associated commands
* = move cursor Left
# + 1 = delete
# + 2-9 (+0) = characters
For characters the associated number will display the first letter and move the cursor one position to the right. For subsequent letters press 0. Say you want the letter L. Press # + 5 to display J. Press 0 to display K. Press 0 again to display L.
For chartacters Q and Z ????
Example: To change my displayed name to TODD
DN + #621
* to left most position (beginning)
# + 8
6 + 0 + 0
Anonymous
Level 1:
  • Posted on Nov 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
6708
Points
I tried to do DN *621, but it only says DATA PROGRAMMED. Will anything else work?
Anonymous
Level 1:
New Friend:
  • Posted on Nov 08, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6708
Points
WHAT IS DN? I THINK I READ ITS MY EXT # BUT IF I ENTER MY EXT # AND TRY TO ENTER #621 IT SAYS EXTENSION NUMBER BUSY
Anonymous
Level 1:
New Friend:
  • Posted on Mar 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6708
Points
No solution but same thing happens with my DKT3210C-SD
Mali Rogers
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 29, 2015
Mali Rogers
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8242
Points
7
Press Intercom and then #621
How do you send a voice message to a different extension?
  1. During or immediately after playing a message, press 6.
  2. Press 2.
  3. Enter each extension number followed by a #.
  4. Press # again to finish. For example:
    • To forward a message to extensions 201, 202 and 203, key in: 201#202#203##
    • To forward a message to extension 201 only, key in: 201##
To return to the previous menu or to cancel message forwarding:
  1. Press #.
On a Toshiba DKT3020-SD how do I add a night time message?
Here is the location of the manual for download: http://www.manualslib.com/download/375822/Toshiba-Dkt3010-Sd-Digital-Phone.html
How do I turn off flashing message notification?
Try leaving the phone on the hook and entering Intercom #409. You may have to do this a few times if the "phantom messages" are stacked up.
What is the log in code to change the name on your mailbox?
The display name in voice mail is normally programmed by a computer having access to the programming. This is the name associated with a mailbox in programming. Find out who has access to make these changes.
Toshiba DKT2020SD Phone Change date/time
Changing time on Toshiba DKT3020-SD
5helpful
How do I change the name on a nortel phone?
To chane the name on the sets you'll need to enter telephone programming.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
1helpful
2answers
Change the inter callers name
ex. john = 5 -> 666 -> 44 -> 66
2answers
On a Toshiba DKT3020-SD, how do I enter the User Programming Mode. I tried pressing #9876 but it did nothing.
There are two programming modes. One is User the other is system. for user programming press 3,6,9,hold at same time. For system type hold *#*#1*2*3* and enter password 0000
Phonebook on Mitel Superset 4025
It depends on your Mitel Telephone system.
If your system is an SX200 ICP ~ then going thru the Blue Superkey options the Mitel will let you change your own name.
But ~ if you have a 3300 ICP then the name change is only performed via the system programming.
Merian M7324 display name
you would need to get into the admin programming to change the name, have your system admin person make the change for you.
Top Toshiba Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
