Element Electronics FLX-3211B 32 in. LCD HDTV Logo
TARITA GETHERS Posted on Apr 18, 2013
Element 32" hdtv when I turn the power on it shuts off right away
I have a element 32' tv win i turn it on just gos 2 blue sceen replaced the power bord y please help
you mean no default element power up
or menu settings ?
what happens with the old remote
does that recognize the new printed board
any control buttons in the frame working
do you have the power source working at specs
and the correct replacement circuit board
Element ELEFW328 32" 720p 60Hz Class LED HDTV
Mar 06, 2017 • Cell Phones
1helpful
My Sony TV only powers up if I unplug H2
Sounds like you are in the right direction. Replace the board, but if your supplyer will not restock the part if not needed I would find a supplier that will.
Any ideas on what to do for an element tv that won't turn back on..the red/blue light is not on either. It was working fine and when I shut it off the red/blue light went out also now I can't get it back...
Tries tv unplug,replug it back like about an hour.By letting the tv resetting itself back to the tv factory setting.Now,the tv should be working again.If it still have the same result.Mean the tv power supply board,that the board where the power a/c plug into it.The causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
My dad has an element LCD tv that won't turn on. I
Looking is one thing and testing is another. You will have to check for the 5 volt standby on the power supply then check for activity from the micro to turn the power on to the run state.
2answers
Insignia 32" begins to power up but shuts down right away
Unfortunately, your TV requires repairs. In-home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
2helpful
My element 32 hdtv does not want to stay on
These units are having a problem with component failure. This has caused the television to got into the protection mode.This protects the unit from more damage. The units need to be taken to a service center for complete testing and service.The service center will have all the service information to evaluate the problem and repair the unit. The Element customer support telephone number is 1-888-935-8880. The Element customer support website is: http://www.elementelectronics.com/support.html Give them the model number of your television and the problem you are having with the unit failing to turn on.They will be able to tell you how to get you television serviced. I hope this information helps you with your problem.
2answers
Element hdtv flx3210 shuts video off after a few seconds.
Send the set back for service.
The power supply most likely failed, or another circuit board has failed and the set is in the protect mode.
I would consider to see if the dealer would exchange the set for a well known quality brand name set and pay the difference.
Jerry G.
Top Element Electronics Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
