Boss ME-70 Guitar Multiple Effects Pedal Logo
A
Anonymous Posted on Apr 17, 2013
My Boss ME-70 Pedal doesn't fade out smoothly
It sustains very well, but when it's fading out, it has like a small crackle or a"spotted up" fade out to it... Any idea why that is?
Jason
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 16, 2018
Jason
Contributor
Level 1:
Answers
Questions
0
Helped
573
Points
Hi have you ever got your boss me 70 fixed. I got the same problem.
  • Jason Feb 09, 2019
    Yes just hard reset and solved all the problems
Andy Throupe
Level 1:
New Friend:
  • Posted on Mar 28, 2015
Andy Throupe
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
573
Points
Hi
Not an answer but a repeat of your question. Did you manage gto fix this as I believe my unit may suffer from the same problem. Thanks
1 Related Answer
Anonymous
  • 59 Answers
  • Posted on Sep 06, 2011
SOURCE: How do I factory reset
press pedals 3 & 4 at the same time to swtich to Manual Mode. Hold down EDIT/EXIT and press the MOD pedal. Press WRITE twice.
Contact boss
BOSS ME70 Factory Reset.
Just do this:
Boss ME-70 distortion changing mid play why.
Is distortion changes like we turn the OD/DS selector (changes to Boost-Natural-OD1-Blues etc)?
If so, the OD/DS potentiometer need to replace.24346541-2ss5ycyvkoajtv035dpuezke-4-0.jpg
If the changes are like increasing/decreasing GAIN/BASS/MID/TREBLE/LEVEL and also TYPE of pre-amp, then one of PREAMP potentiometer is bad.24346541-2ss5ycyvkoajtv035dpuezke-4-1.jpg
My casio privia px830 pedal doesn't sustain enough,
It could be that the electronics of the pedal are dirty, or that dirt has collected under it causing it to not depress all the way. Try taking it apart and cleaning it with a Q-tip and rubbing alcohol. Be very careful of any wires or delicate articles.
11helpful
2answers
How do I factory reset a BOSS ME-70 effects pedal
1helpful
Quik lok stereo vol pedal crackles
spray the controll with cleaner. if it dosen't work replace the controll
When I plug the fc-5 pedal into a P95 piano, sustain in ON (either I press the foot switch or not) and when I unplug it, sustain goes off, and sometimes it is vice versa, pressing the switch doesn't...
Sounds like a loose wire to me (because the problem isn't consistent) the most likely suspect is the jack plug. Unscrew the body of the plug and check that the two wires are firmly soldered to the terminals inside.
If they're OK you can pop the cover off the footswitch and check that end. As far as I recall that end of the cable goes straight to a PCB (printed circuit board) so be very careful if you need to solder anything. If the solder around the wire connection is cracked, that's a dry joint and can be fixed with a small blob of solder carefully applied.
If all the cable connections are fine there's a problem with the PCB or the micro-switch mounted on it.
1helpful
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
My DD7 delay wont turn on. The red indicator light will flash for a few seconds then it fades away and does nothing.
If on battery, battery is depleted. If on adapter, connection is probably bad. Often power jack is broken or has bad soldering.
1helpful
5answers
How to set up foot switch in order
Personally I recommend the following set up:
Distortion>Effects>Compression/Noisegates/Sustain
This will ensure that the signal won't have any odd hiccups due to an odd pedal setup. But if you play around with different orders, you can end up with some very interested sounds.
1helpful
Roland DP-2 pedal not functioning correctly.
There are two types of damper pedal switches, on that is closed until you press it, and one that closes when your press it. It sounds like your Casio is expecting one type and your Roland pedal is the other type. A quick way to test this is to plug a guitar cable into the Casio pedal input and see if the keyboard sustains. If it does, then your Casio requires an "normally closed" switch.
Some pedals have a small switch near the cord or even on the bottom of the pedal that will reverse the switching operation (BOSS pedals, a division of Roland, have this feature). If you can find that, then change the switch position and you should be OK.
If not, and you feel like digging into your pedal, you could take the bottom off of the pedal and check out the switch itself. Many pedals use a switch that can be used either way. The clue will be on the switch itself. If there is an extra tab on the switch that is unused, then switch the wire that is furthest away from that tab to that tab. This will probably involve soldering, but it is nearly impossible to damage anything.
If moving the wire that is furthest away does not do anything, then try putting that wire back and switching the other one.
If your pedal does NOT have an extra tab, you're SOL, unless you want to buy a replacement switch (unsure of make). If this is the case, you are probably better off getting a different damper pedal - preferably one that is marketed as "universal"
Top Boss Music Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a Boss Music Expert? Answer questions, earn points and help others
