When you press power button red front lite turns green, blue screen with akai logo comes up on screen, then set shuts down and green lite turns back to red
I have a LCT2070 AKAI T.V. that will not stay on. When you press power the white srceen with the AKAI logo comes, and yu hear a staticy noise, then the TV goes off. When It first started you could turn it on a few times and it would finally stay on, but now it will not get pass the logo and it goes off.I have a LCT2070 AKAI T.V. that will not stay on. When you press power the white srceen with the AKAI logo comes, and yu hear a staticy noise, then the TV goes off. When It first started you could turn it on a few times and it would finally stay on, but now it will not get pass the logo and it goes off.
You can't post conmments that contain an email address.
CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
Rating: 1.9 - 37 votes
The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
AKAI PT50DL14XSMS - LAMP INDICATOR (GREEN) FLASHES ABOUT 20 TIMES - CAN HEAR FAN RUNNING AND LOOKING THRU LAMP GRILLES CAN SEE BRIGHT BULB LITE - NO PICTURE COMES ON - AFTER ABOUT 30 SECONDS EVRYTHING SHUTS DOWN
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
First turn your DS off.
While the DS is off, press A and B at the same time. While still holding, turn the DS on. Then when the Nintendo DS logo appears, press Start and Select at the same time, aswell as A and B. Hold those 4 buttons down for about 20-30 seconds. Then while STILL holding down those 4 buttons, turn the DS off. Turn it back on with no buttons pushed.
In about 95% of the time if the TV is not powering up, the power supply needs to be replace or repair. I've repaired a few hundreds ot these power supplies.
Let me know if you need further assistance.
These TV's are prone to power supply failure. I can fix the power supply on this TV for approx $100 +s/h.... Contact me and all you have to do is remove the power supply and send it to me and I will repair it with high quality parts. Reinstall and you TV will be good as new...
Do you still have this TV?Sounds to me like a bad capacitor,or two.I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
