Samsung UN-40D6000 40" MULTISYSTEM LED TV FOR 110-220 VOLTS Logo
Posted on Apr 17, 2013
How to change resolution on Samsung 40d6000
I cannot get my HD device to play, the screen say I need to change the resolution settings.
1 Related Answer
marionbagget
  • 718 Answers
  • Posted on Apr 15, 2011
SOURCE: We have a Samsung LE32R74BDX EU HD TV We have just
A manual is at;
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=101&prd_mdl_cd=LE32R74BDX%2FXEU&prd_mdl_name=LE32R74BD&srchword=LE32R74BDX%2FXEU
You can download a number of files at this location. The files are in PDF format so if you need the adobe reader you can get it by clinking on the link at the bottom of the page.
How to fix screen resolution?
, clicking Control Panel, and then, under Appearance and Personalization, clickingAdjust screen resolution. Click the drop-down list next to Resolution, move the slider to the resolution you want, and then click Apply. Click Keep to use the newresolution, or click Revert to go back to the previous resolution.
Change your screen resolution - Windows Help - Microsoft Support
https://support.microsoft.com/en-gb/help/14108/windows-7-change-screen-resolution How to fix screen resolution Google Search
6answers
How do I change my LG 4k to a higher resolution.
It depends on your source video resolution. If you're willing to play in 4K, you can upscale your 1080p or 720p video to 4K resolution in advance. Here is the video tutorial:
After conversion, it will be played in 4K on your TV. Of course, it's all based on that your TV supports 4K.
A manual is at;
Hi, I have a samsung star s5233, and from few days i am getting a problem, when I am playing a .mp4 video of resolution 320*240 its only play audio but inspite of video I see only blank screen.... Tell me...
Seem like your device don't recognise the video format or the resolution was too big.
Convert your video in resolution that compatible with your screen (try Format Factory or other converter) and use widescreen setting, use .mpeg4 for video setting (instead of AVC or Divx), use 15 fps video speed, and .mp3 for audio setting.
This should be work and you can watch the video in your cell phone.
You can download the converter from here :
http://format-factory.en.softonic.com/download
Be kind to RATE please !
Samsung SyncMaster 2233SW Monitor "Not
The "native" resolution of the monitor is the "optimal" resolution -- it looks best to use this resolution.
So, right-mouse click anywhere on your Windows desktop "wallpaper".
Click Properties.
Click Settings.
Move the "Screen Resolution" slider to the recommended settings.
Click Apply.
Click OK.
2answers
I want to run a software which requires a screen resolution of 1280 x 768 but my Samsung SyncMaster 740nw supports up to 1280 x 700 screen resolution. Is there anything that I can do? Please guide.
Have you tried adjusting the screen resolution in Control Panel - Display - Settings and moving the slider on Screen resolution?
Normally a monitor such as Samsung LCD would be able to display a higher resolution.
If you cannot adjust the Screen resolution in Display - Settings then it may be that the correct video driver was not installed or is corrupted.
To check if the video diver is OK, go to Control Panel - System - Hardware - Device manager and click on Display adapter. Check that your display adapter is OK and working. If you see a yellow ? against the video adapter or a standard VGA adapter was installed then you need to re-install the video driver for your model graphics card.
1helpful
I AM FROM INDIA I RECENTLY PURCHASED AN AIRTEL DTH HD VERSION, SINCE I HAVE A SAMSUNG LCD MONITOR (SYNCMASTER 2233sw) WHICH SUPPORTS FULL HD (1920X1080). MY MONITOR RUNS FULL HD WITH DVI CABLES OF...
Hi gurmeet,
What I suspected from your description of problem is that there is some kind of compatibility issue or content protection when you plug in an additional HDMI to DVI converter.
I am also using an Airtel HD connection, though however, I wouldn't need any kind of converter because I am directly connecting HDMI cable to my LCD and it works like a wonder. I set up my box output resolution to 1080i and there is no display resolution mismatch. Not even at other resolutions.
Airtel is using 1920x1080 resolution in signal transmission, so the possibility of 1079 from there end is ruled out, otherwise, the same problem would have been observed when direct HDMI cable is being used. I hope you understand my point.
Now you might also ask why you weren't able to see this problem when you connect the monitor to your PC graphics card. I would like to tell you that graphic cards are very versatile and does have the capability of 1:1 pixel mapping, so there you wouldn't see any such problem.
read this link for more http://www.hdtvsupply.com/hdtodvico.html , where a person is able to match resolution using a similar converter.
I believe the converter you use isn't able to do 1:1 pixel mapping and is actually downgrading the resolution which your monitor is not able to support.
You can try out other resolution type from the STB and if you still see similar problems, then you may need to get an alternative converter.
Follow these steps to change the STB resolution type;
Enter the Menu from STB remote -> scroll to 'My Settings' -> Enter 'System Setup' -> 'HD Setup'. Here you change to a lower resolution and press ok from remote.
Poor resolution
Try to change the screen resolution on your computer right click on the desk top properties then settings tab. If this does not help try adjusting the video options on the tv like contrast and such.
HD-A3 Movies Don't Play Video, but Menus are fine?
Might be a resolution issue, the menus are most likely in 480, while the video might be in a resolution not supported by your tv. Try changing the resolution and see what happens.
1helpful
2answers
Games run on hdmi, but not Blu-ray movies
You most likely have the updated drivers. You may have to go and change a setting. I found an answer on the PS3 website that may be of some use to you. I hope this helps you: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191 From the site: "go to bd/dvd setting and set the "108024hz" option off"
Top Samsung Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Samsung Car Audio and Video Expert? Answer questions, earn points and help others
