Correct voltage Greg?
Then yes it will work
More Wattage means more Amperage.
Same voltage, but more Amperage
(Voltage times Amperage = Wattage )
KEEP the inside of your laptop CLEAN
Make sure you occasionally replace the Thermal Paste on the Processor (CPU), and Thermal Pad on the graphics chipset. (GPU)
Service Manual for disassembling the laptop?
Everex is out of business (To my knowledge), and I see no service manual available.
I should be able to step by step you through it, anyway; if you desire
Regards,
joecoolvette
SOURCE: oper. sytem will not load w/ 2 Gb upgrade only w/
Is your "2GB upgrade" one memory-stick, or two?
If it is one, then it's possible that the motherboard does not support so much RAM on one stick.
If it is two, then remove one stick, and try.
If it still fails, then remove that stick, and try the other stick.
If it still fails, then try your original 512KB stick.
If it still fails, then try your original 1GB stick.
SOURCE: need the power jack for the Everex Everex StepNote
you may want to make sure it is not the power cord first, i thought mine was the power cord, I plugged it up to a different laptop and it worked. so it is something in the laptop..
SOURCE: my Everex Stepnote Nc1502 is not working. It just
As it not be on before or for one try telling us better what exactly happen to it with symptoms is shows ok
SOURCE: Sound device not available in Everex Stepnote
hello you will find the drivers at the below link goodluck
EVEREX STEPNOTE
