I have searched the manual for answers.
SOURCE: how to unprotect the memory card
the problem isnt with your camera, its your memory card, and it isnt a problem at all. simple solution- take out your memory card, and on the side there is a tiny switch. all you gotta do is flip the switch. quick and easy. hope that helps anyone.
SOURCE: Cannot remove memory card write protection Nikon Coolpixs9
Take your memory card out and look to see if you may have moved the sliding switch on the memory card, if you have move it back.
SOURCE: I put my memory card in my camera and it says
Your memory card is protected and this is why you cant take pictures.
To solve the problem do the following:
Your problem should now be solved!!
Enjoy taking pictures!!
Regards
SOURCE: It says my memory card is protected
On the side of the memory card, there is a small slider that locks and protects the memory card from being overwritten. Yours may be in the locked position. Simply pull out your memory card form your camera and unlock your memory card by sliding the tab.
Hope this helps,
Andrew
Do not forget to vote.
SOURCE: Vivitar ViviCam X014 will not turn on. Memory
Buy a real camera. X014 is cheap and has a foggy cheap lens. It will never take a good quality picture. It is a waste of a 10 megapixel chip!
