Water registers half full when no water is in it. if you take the reservoir out and put it back in it registers something differently each time
SOURCE: Water leaking from the base of the unit.
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
SOURCE: My cuisinart carafeless coffee maker is not working..
dear,
read this comment and you will get what u want .
or if any confusion, read its manual keenly.
regards,
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
SOURCE: Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
SOURCE: Cuisinart COD 4000 coffeemaker
Just a comment; most of the coffee maker failures are caused by the premature failure of a thermal fuse that is intended to prevent fire in case the main heater doesn't turn off as it should. Unfortunately, most of these parts come from China and are very poorly made so the point at which they 'protect' is pretty unpredictable, many of them failing at a much lower temperature than necessary. The second most common failure is the thermal switch that cycles the main heater element; these are bimetallic switches that grow 'tired' and the point at which they open and close again gets wider apart until it can take an hour for a 12-cup pot to finish brewing.
