Question about Lewmar Pro Series 700H Horizontal SS Windlass
Why is my windlass locked up, lewmar pro
Letting out and pulling up anchor will not work. Up and down switch works windlass will nnot operate. power is connected.
Hello, I have a lewmar Concept 1 windlass that worked fine for May/June, then on vacation in July it started cutting out. If I let it sit for a minute, it would start up again, only to quit again after...
Check the brushes and if they are short just replace them.
This will solve the problem.
There is thermal cut out which will protect the winding if its hot and will stop windlass and after cooling down it can run again.
Oct 28, 2017 | Lewmar Concept 1 Windlass 5/16" Gypsy With...
During a hauling in operation the windlass started to making a strong noise and the gipsy stopped turning. I checked the clutch but it was OKAY. I have a little video where you can hear the noise. If...
I would check the wire leads off the windless to switch and from switch to battery (typically ground) During times of extreme load thoes thick wires heat up expand and contract and might loose a little contact or corrosion. Thoes windlesses are pretty bullet proof and very rarely have i seen one break. So I don't think its the winch itself. I would start there. Good luck Aloha
Feb 25, 2018 | Lewmar V700 Vertical Windlass - 12V 1/4" W
Unit will not pull up the anchor
First, put a volt meter across the winch's power terminals to verify that the voltage is not dropping several volts when comanded to run, indicating a bad cable connection somewhere. Anchor winch's pull alot of current from a battery.
For a test, use car jumper cables from a good battery to the winch to see if it runs better.
Oct 18, 2009 | Boating
I need fan/heat sink anchors for 775 cpu. nylon tips broke off letting fan pull away from cpu can I buy the anchors only. desk pc is custon built.
If you have another heat sink laying around, perhaps in an old computer you don't use? Try using the anchors from that.
I have also had success mounting fans to heat sinks using wire ties. Not sure that will work with your problem though because it seems you're talking about the actual gadget (usually a piece of metal) that locks the heat sink down onto the CPU.
Aug 23, 2009 | Computers & Internet
Sprint 600 Vertical Windlass blows fuse
Is this the main fuse???
600watts motor on a 12V system drops 50amps...
You should have an 80 or even 100 amps fuse for the power cables!
Jun 15, 2017 | Boating
Powerwinch windlass not working.
Of course, first check the voltage at the connections to the windlass. Have someone operate the switch while you measure with a volt meter. If no voltage check breakers, or fuses. Heavy current devices like a windlass will often require fuses near where they connect to battery power.
A windlass requires a LOT of current to run. Not just voltage. Trace the wires from the battery connection all the way to the windlass. If possible, loosen any connections (ex; a lug with a nut or bolt) and clean with a wire brush then reconnect. Be sure to disconnect the battery while cleaning. Many times wires will corrode past the insulation. Especially if they were not tinned wire to begin with (tinned wire has a silver shine, regular copper has a copper color and typically turns dark or even black when corroded).
Since a windlass requires a lot of current, often there may be a relay near the windlass that might go bad. Listen to see if this is activating while someone operates the switch.
Apr 27, 2017 | Powerwinch 36' Class Freefall P77736 775...
I have a Lewmar Sprint 600 Windlass. It was working, however, my battires were low and there wasn't enough power to run the windlass. I think trying multiple times, I trick the breaker. I charged the...
I had the same problem this past weekend. Took the complete unit apart and found salt and all kind of moisture in the motor itself. It sure was not sealed very well from the factory. I am unable to find the motor sold separately, therefore I am taking my unit to an electric motor shop. I am guessing it will cost me about $100-$125 to get the motor reworked. It was extremely easy to take apart.
With the moisture in the motor, there was simply too much resistance for the windlass to turn, If you get your tension wrench and work the windlass back and forth, then hit the button. It should work temporarily.
Good Luck,
Tony
Apr 14, 2009 | Boating
Wiring two circuit pull switch boat lights
3 terminals.. 1 power input & 2 x outputs
Main positive goes to 1 terminal = power in to switch.
The anchor goes to another terminal = power out from switch to anchor
3rd terminal is another output for lights/anchor.
Mar 28, 2009 | Cole HERSEE PUSH-PULL SWITCH -- OFF-ON
Lewmar Pro Series 700H Horizontal SS Windlass Logo
157 people viewed this question
Top Lewmar Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lewmar Boating Expert? Answer questions, earn points and help others
