Okay, to be of real help you have to reset the error in service mode as the officetech1 said. To do this you need to press the head key (the head with the star inside) then 2+8 together and then the head key again. This will get you into service mode. Then select 'COPIER' then 'FUNCTION' then 'CLEAR' then select 'ERROR' or 'ERR' press 'OK' then switch the machine off and on again. This may get it working for a while or a long time. But if not, you will need a fixing film unit to remedy the problem.
thank you.
its been fixed.
I was facing the same issue before contacting best buy geek squad -https://best-buy-geek-squad.net/
Had been faced with this error for over 3 days with the machine not able to work and not knowing how to fix it myself than to call the repairer. Thank you for this simple guide. It was helpful and simple to perform.
E00000-0001
When I turn on the power, the screen display above error code. I was asked to shut down the machine and turn on the power. If the error still exists, call the service provider
E00000-0001
E00000-0001
SO NICE SOLUTION TROUBLE SHOOTING
E00024-0001 display in ir 3035A. wath is problem plz sugest me .
My machine does not operate and then it shown an error code e00000007-0001 number of machine canon ir 3045 so what im i suppose to do
IR 2870 Show in E000000-0001 pls suggest me
This is a common problem of an error of screen. You can solve easily as a set of a system and Peripheral Settings or you can contact to Ricoh printer support for better service Ricoh Printer Support 1 888 234 8031 Customer Helpline
The fixing unit needs replaced. The error can only be reset by going into service mode but if this happened 99 percent sure you need a new fixing unit. they are not cheap.
the machine just wont work turn off and on sever times left off off days and still the error code
THANKS
Additional functions+ 28 + additional functions device mode go to copier clear error
