Blocked or clogged water input line
Sucking air from a leak, not enough water thru system
Excessive debris in strainer baskets
Filter needs to be backwashed
Filter needs new sand or new cartridge
Filter needs to be taken apart and "fingers" cleaned
Filter Pump Impeller is obstructed
Filter motor is in-correctly wired
Filter motor bushings need replacement
Filter motor bearings are worn
Filter motor is "shot"
SOURCE: I have an Emerson 1081
How old is the motor? Is it operating louder than normal as it runs indicating a bad bearing? Have you or can you check the incoming line voltage to ensure it is correct? If it is a new motor have you made sure the motor is set to the correct incoming line voltage? Has anything in the plumbing changed recently?
John
