SOURCE: kenmore electric range 95022
there is a problem with the door lock switch assembley a bad switch or the lock motor or the oven light switch
SOURCE: I ran the logiclean cycle on the oven and nearing
Hi
Thanks for using FixYa. Error F5-E1 indicates an
issue with the door latch. To resolve this issue you’ll have to check the door
latch/switch. If they are not working fine you’ll have to replace the part that
has gone bad. Please do rate the solution if the issue is resolved or post a
comment for further assistance.
Thanks
Rylee
SOURCE: My display is showing E1 F5 and the self cleaning
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#$R
