Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF566P, works as normal until the end when it is stuck with 1 minute left on the cycle. It will stay like this until switched off at mains. When switched back on again, it will complete a full wash again until 1 minute remains of the cycle but again the cycle will not end. Any ideas to solve this?
    Top Expert:
  • Hotpoint Master
  • 51,923 Answers
The timer is "hanging" and probably will have to be replaced.
Posted on Dec 29, 2017
SOURCE:
  • 16 Answers
SOURCE: Wash light is blinking
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or blown heating element caused possibly by a blocked pressure chamber.
Posted on Feb 08, 2008
  • 100 Answers
SOURCE: test on display cant use washer
turn the machine on while you press the start and on buttons at the same time until dOFF appears.
Posted on Feb 28, 2009
skrbin
  • 121 Answers
SOURCE: Won't complete wash cycle, stuck at wash after time end!
check heater or thermostat,check is it heat water
if not heat water then heater or thermostat is broken.if you have ohm meter you can check both
,unscrew behind sheet metal and find heater disconnect one wire from it and check it(meter must show some value e.g.30 ohm).
Posted on Jul 05, 2009
SOURCE: hotpoint first edition washing machine fault- full
mine was doing the same it was the bearings
Posted on Sep 23, 2009
  • 4088 Answers
SOURCE: why does my washing machine trip the electric
Someone with a wattmeter needs to read the wattage load by the machine when washing. If the running load is greater than the rated load of the machine, then the problem is likely the motor itself or the drum bearings are going bad. If the electrical load is normal, then the breaker in the house electrical panel is either under-rated, or the breaker is defective. If the breaker is a 'ground fault' type, the washer may have current leakage to ground causing the breaker to trip. Another possibility is that there is another outlet that is on the same circuit and the combined load trips the breaker. Shut the breaker off and try any other sockets in the area to see if they went dead too. Hope this helps!
Posted on Oct 28, 2009
How do I stop my Hotpoint washing machine WMF740 which has been going for 7hours and is stuck on 1 minute
Is there a way to manually advance the cycle or is it all digital control panel? Do you see a reset button anywhere? Check the link I'm sending you on the manual.
Hotpoint Washing Machine Instructions For Use ManualsOnline com
Nov 24, 2014 | Hotpoint Washing Machines
Reset WF566P washing machine
UNPLUG MACHINE FOR 2 MINUTES THEN PLUG BACK IN, BUT FIRST PULL THE OFF /ON KNOB OUT THEN TURN AND LEAVE IN OFF POSITION, THEN OPEN CLOSE LID SLIGHTLY 6 TIMES WITHIN A 12 SECOND PERIOD
Aug 11, 2014 | Hotpoint Washing Machines
Cotton program stuck on wash cycle with 1 minute left
Control board needs to be replaced. Many times the control boards go bad because of a spike in the electrical grid cause by a brown out, lightening strike or even a surge in the power. After the control board is replaced... I suggest using a surge protector on all of your electronic devices including the washing machine.
Feb 06, 2014 | Hotpoint Ultima WF865 Front Load Washer
Cae2743bq will not turn on all lights on and lid lock is lit up
Try this, worked for me! :)
New WHIRLPOOL Top Load Washer
Model #'s CAE2743BQ, CAE2763BQ
Cycle Selector Knob key dance: [CCW=Counter Clockwise and CW = Clockwise]
Start On "NORMAL"
1 step CCW (Left)
2 steps CW (Right, Right)
1 step CCW (Left)
1 step CW (Right)
Stay on "HEAVY DUTY"
(If unsuccessful LEDs will not flash, and you must return the selector to the Normal Cycle position and
wait 4-5 seconds before retrying. )
If you are successful in the process, all LEDs will be flashing
Toggle between HEAVY DUTY and NORMAL until ONLY the RINSE light is on, then press the
START button for about 30 seconds. Machine will then enter CALIBRATION mode for about 2 - 4
minutes. DO NOT RAISE THE LID
Sep 01, 2013 | Whirlpool Washing Machines
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My Hotpoint WMF740 washing machine is displaying a 'door' error message. The machine started to make a funny noise and then stopped approx. 15 minutes from the end of a 1 hour cycle. The door opens alright...
it very well is the door switch might be stuck. The way to unstick it is to slam the door. Very often it'll jar the switch loose if that doesn't work you'll need to order one. Easy to install there are youtube videos on it. If you need the part...try here...repairclinic.com or appliancepartspro.com.
Hope this info helps a little.
Jan 04, 2018 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint WMA33 washer - door won't open
Problem seems to have corrected itself! I tried another slow spin cycle, waited a reasonable interval for the Door Locked light to go off, then when it didn't I switched the power to the machine off. I tried squeezing the door catch a few times and pressing the door downwards, then left it. Some time later when I went into the kitchen the door was open. I washed a small load this morning and the machine worked normally. Fingers crossed, it's ok now.
Oct 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WF865 Drum getting stuck?
I THINK IT MUST BE A LOOSE COIN,STUCK IN MOTOR
Feb 08, 2007 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
182 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
