SOURCE: language setting
Try this: 1. unplug all cables from back of unit (turn power off as well) 2. while the printer is off hold down the * and 5 3. while holding them turn printer on 4. continue to hold buttons until display reads 'Permanent Storage Init' 5. then release buttons 6. at the end of reset it will ask you to select language and location, just press enter then 1 to confirm Hope that works!! Ed PS. You could have picked an easier language!!!
SOURCE: 3015 hp laser jet printer window in foreign
Should be tools setting go to factory reset change language to English
SOURCE: HELP trying to change back to english
Just un install and reinstall.
If problem then keep me posting!
SOURCE: Hello, I have problem with hp
Go to hp.com.
Download and install the latest firmware.
The instructions are given there.
SOURCE: sir how to cancel printing
If I understand you question correctly:- go to "printers and faxes" in the Control Panel, select your printer, highlight the command printing your job and click on 'Document' 'Cancel'. it takes a little while to stop printing. Otherwise check your printer documentation, there may be an instruction like holding down the 'on' switch for five seconds to clear the printer instructions.
