Issue:
Banded or streaked prints
Solution:
Change the Print Quality Settings (Windows)
The
Quality setting controls how finely ink droplets are placed on the
printed page. Depending on the type of paper being used a higher Print
Quality setting does not always insure a better print. Print speed will
decrease as the Print Quality setting is increased. Follow the
instructions below to change the print quality settings in the Canon
printer driver for the Windows operating system through a printing
application.
- Click 'Properties' in the Print dialog box.
Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
- Set the desired print quality in the 'Print Quality' section.
- Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
- Select 'Custom' and click 'Set'.
- In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
- Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
