I have encountered a similar problem. The following lights were flashing on and off:
I also found that previously one of the 'lifters' inside the drum had
broken off and someone had tried to put it back in place and continued
to use the washing machine. After a short period of time the above
mentioned flashing lights began.
I first suspected the pump, but this was fine. I then disconnected the
hose which connects the hole from the drum to the pump and I found a
child's sock blocking the hose. I removed the obstruction, put it back
together and the machine worked perfectly. I also replaced the lifter
(apparently these break quite often) and the machine has been working
perfectly ever since that day.
I hope this helps. Good luck.
Same problem with mine, took the pump hoses off and found a pair of knickers and 2 plastic forks! All working great again now, thanks.
Exact same problem here, thanks guys. A 10p coin in the pump. Could on be removed with the pump out of the machine.
i phoned the helpline and they said the filter may be blocked
