This is a problem that has evolved through many stages throughout this week. It started when a friend wanted me to play DayZ with him. little did i know that this particular machine couldnt handle it..all still worked fine for a while, in the mean time, i was looking to update the graphics card. .before i could even find one, the computer decided to suddenly boot to only a black screen with the mouse icon. before proceeding further, i decided to call customer support..which wasn't very helpful...i've never had someone from India hang up on ME before..LOL! ..(yup, that happened..) he couldnt "understand the problem". at anyrate, i decided to try Restore Points. It worked great! until i shut down my computer and went to turn it on the next day...had to do another restore point...& so on..all restore points became exhausted, so i tried to do a Win7 reinstallation (while keeping my files safe)..which brings me to where i am right now: "Windows could not complete the installation. To Install Windows on this computer, restart the installation" followed by "Setup will continue after restarting your computer" *restart...Starting Windows logo...Setup is starting services..* and BAM "Windows could not complete the installation. To install Windows on this computer, restart the installation." ..rinse & repeat.. i've F8'd every option to no avail...also worth noting, this PC doesnt have an installation CD... if there is someone out there who can help, i would greatly appreciate it :) Thanks
SOURCE: Monitor will not start up!!
سلاموو..
يوجد لدي"acer T310" المشكلة الي فيه...نسيت الفلاش ديسك مشبوك فيه...ولمن أعدت تشغيله طلب مني أضغط على "F1" لحفظ التغيرات .... وأنا طبعاً فصلت الفلاش ديسك بدون ماأضغط ال"F1" وأعدت التشغيل.....هنا ظهرت المشكلة..لم تظهر الشاشة.
طبعاً حاولت أفصل الرام عشان أسمع إذا بيجيب صوت إنه الرام مش موجودة ....لكن ما جاب صوت نهائياً...
ومش قادر أحدث ال"BIOS" لأنه ما يدخل على ال"DOS" نهائياً...
فيا ريت من معاه حل لايبخل عليا ويرسل لي على البريد الموضوع تحت..لاننا صدق زعلان على خسارة الجهاز..
وشكراً على إهتمامكم بنا...أخوكم ....كمال حيدر
البريد هو/ [email protected]
ولكم جزيل الشكر والإمتنان
SOURCE: unable to reboot or log on since restore system to factory defaul
Go into the bios and revert to set up settings/default and reboot.RICHARDM69
SOURCE: PC doesn't work well after installing Windows VistaService Pack 1
I have no idea what is going wrong but trying updating to Service Pack 2. I found on my computer it runs alot smoother and supports all programs so that might be the solution your looking for.
SOURCE: I have an acer laptop. I downloaded service pack
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
also you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
then defragment your hard drive also
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
dont forget to vote
SOURCE: I keep getting an error screen after a system
If this was a windows system restore try picking another date before the one you just carried out.
Its going into a loop because its missing some information ,or your restore method was not windows system restore but acer recovery only a drivers and OS system restore,try pressing F8 on start-up and see if it will boot into safe mode this should allow you to check all the drivers and also do a virus check which I suspect is Master Boot Record based, If the problem persists and you have no way even after trying out safe mode use complete Acer System Recovery to factory defaults this will then make a backup file on the desktop labeled windows old backup where you can then recover documents,music,photos etc
Testimonial: "Thank you. I have tried Safe Mode, Restore with keeping my files and a restore to Factory Original and all give me the same results."
