SOURCE: I have a Nordic Track exp1000 i fit and the track is not working.
It's either the electronics console overlay -- this thing often goes on this model -- or your motor is shot.
Have you ever seen it working?
Repairs can expensive.
You can buy an excellent replacement console electronics part for $100 (http://www.treadmilldoctor.com/Nordictrack-Console-Keypad-Overlay) , but if it's actually the motor, then you've still got more to spend.
In home service can easily run $150 for the call plus cost of parts.
If you decide that you're not going to try and get it repaired and you're going to toss it, I'd like to buy some plastic housing parts off that non-working unit from you. Please email me directly.
Cheers,
Mark
[email protected]
SOURCE: Need to put together a Nordic Track Elite 2900 treadmill.
Type into the serch, icon health and fitness, then click on the customer service, then click onto the manuals and the instructions should be in the owners manual.
Good luck.
SOURCE: Nordic track c2255 console displays FF and will
Hold down the speed up button and the stop button while inserting the operator key,if a bunch of numbers come up hit stop once, if nothing changed the console is bad.If the numbers change pull the key and reinsert it again, if nothing changes the console is bad.Also there usually is a tech sheet and test mode guide on the inside of the motor cover if you remove the screws and take the motor cover off you will see a white paper with lots of info.
SOURCE: Nordic Track exp 2000I. Consol lights, buttons do not work.
If the console lights up but the buttons don't work, then unfortunately it's probably the console and they're not repairable that I know of. You may want to check the wiring harness and the connections at the console and at the controller under the motor hood. Pull them apart and check for bent pins. If they look good, the console is most likely bad.
