SOURCE: PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
SOURCE: Magic Focus does not fix the blue 57UWX20B Hitachi
you need to replace the convergence ICs they are STK392-110 you can get replacements at the following link and they send instalation instructions with pictures so you can do the repair yourself. You need to replace both IC they are both STK392-110 they are located on the large heat sink on the far right side of your Tvs' chassis Heres the link for replacement ICs
SOURCE: hitachi tv magic focus does not work
Your problem is the convergence circuit. This is very common in CRT projection sets like yours. There are a couple of IC's that need to be changed and possibly some resistors. A good repair shop will run you $400-$500 to do the repair.
SOURCE: hitachi 61udx10b
Replace Both of your STK ICs they are your convergence ics they are big black ICs will have Part# on them for example STK392-110, if they are 110s use 180s, if 020s use 040s other wise replace with exact same number. To get Parts call Electronix 1-800-223-3205
SOURCE: When doing Magic Focus on
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
