I WANT TO MAKE MY SCREEN SIZE SMALLER BECAUSE EVERY TIME I WATCH I CAN'T SEE MOST OF THE STUFF THAT IM WATCHING , SO I WANNA MAKE THE SCREEN SMALLER SO EVERYTHING FITS
SOURCE: LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
SOURCE: LG 50PC3D plasma keeps restarting
Unplug power cord- safety first!
open backcover
check powersupply- top center right is p.s.
top left side of powersupply you'll see 5 capacitor 3300uF 10V.
see any pop up on top? replace it All with same rate or 16v is O.K.
do not use temperature rate 75c. Use 105C.
if you know how to solder. you could save $300 at least!
SOURCE: LG 50PC3D w/no picture
Your mainboard is damaged, replace it and that will solve your issue.
SOURCE: my lg 50pc3d will not turn on the power light
Hello sir, hi, the symptom you have describe can be traced on the Power Supply board, either minor problem such as loose connections and screws, or a major one that needs replacement of the entire Power supply board.
You choose:
Have a look, and check for loose contacts, screws that needs to be tighten but you need to open up that big TV.
Or if that does not solve the problem, its the major one, needs to replace the entire PS board.
SOURCE: lg 50pc3d plasma tv will not hold channel/tuning
back up memory has a small battery ....this needs to be replaced,.
