Question about Janome Memory Craft 9500 Computerized Sewing Machine
Warning raise presser foot and needle bar, then turn power on again is on the screen how do i get it to reset? this is on a memory craft 10001.
5 Suggested Answers
SOURCE:
  • 19 Answers
SOURCE: says raise pressure foot and needle bar
check youre screen you will see an icon of needle you have got it in the down mode touch it it will raise it next time you sew it will be raised this is an option to have needle in fabric or raised on completion of sewing this is in your manual.
hope this helps mary h
Posted on Dec 23, 2008
  • 323 Answers
SOURCE: I turn on machine keeps
This machine needs to visit an authorized Janome technician.
sewman7
Posted on Jul 10, 2008
bargainbox
  • 1388 Answers
SOURCE: I need to replace the metal bar that snaps onto the presser foot.
If you go to the Janome website of your home country they will have a dealer locator page where you can find your nearest dealer.
Explain the problem and they will be able to order the replacement part for you.
You may find that parts availability at this time of year will be restricted as many businesses and suppliers close for several weeks.
Posted on Dec 28, 2008
  • 1564 Answers
SOURCE: JANOME 200e,raise presure foot and needle bar then turn of power
Is there a question in there somewhere?
Posted on Oct 05, 2012
Error message #2
Perhaps this error list will help you resolve the problem:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwijuKaq-9fJAhUD6WMKHXLVCyYQFggjMAE&url=http%3A%2F%2Fwww.janomeservicevideos.com%2Fwordpress%2Fwp-content%2Fuploads%2F2015%2F02%2FError-Codes.pdf&usg=AFQjCNHyJmEhmZ9Avh-lSL4Y0vVHEYM1yg&cad=rja
Try lowering the pressure foot and the needle and then raise them
again and then restart the machine, and if that doesn't clear the
error message then it's time to service the machine.
Dec 12, 2015 | Janome Memory Craft Clothsetter 10000
When I turn on my machine this warning comes up raise the presser foot and needle bar then turn power on again #01
Sorry. Unable to advise. Error codes mean different things on different brand machines. Perhaps consult the owner's manual in the troubleshooting section.
Nov 28, 2015 | Sewing Machines
How do I fix the following problem with my Janome MC9000 sewing machine?
Unfortunately you are probably not going to be able to fix this.
It needs a sensor adjusted (probably), or a component replaced.
Sep 25, 2014 | Janome Memory Craft 9000 Computerized...
Janome 9700 suddenly is showing warning. Raise
Ask the seller! He has a vested interest in helping your machine work! As a former newspaper writer, believe me, if you send something to a local rag, about your problems with your Janome, the seller will sit up, and take Notice!
Oct 23, 2013 | Janome Memorycraft 9700 Computerized...
HOW DO I ATTACH PRESSER FOOT G TO MY MACHINE??
there are 2 type of presser bar foot clamps
one allows you to snap on the foot--raise & then lower the presser foot holder until the cut out is directly above the pin on the foot,,as you lower the presser foot holder the presser foot will automatically engage when put down on the pin area
the second is a shank & foot combined & there is a screw on the presser bar,,unscrew it some & put the shank up around the screw & retighten the screw
Nov 24, 2010 | Janome Memory Craft 5700
Says raise pressure foot and needle bar
Dec 18, 2008 | Janome Memory Craft 9000 Computerized...
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just...
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Jun 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Janome Memory Craft 9500 Computerized Sewing Machine Logo
638 people viewed this question
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Thomas F. Schneider
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
