Linksys WAG200G Router  Logo
Posted on Mar 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Portforwarding on Linksys WAG200G wireless modem/router
I have to open a port - for VOIP reasons - on my Linksys WAG 200G wireless modem/router. The port no is: 5060. I know how to get my IP-adress that I need for portforwarding, but then....?
Jim Brauer
Level 2:
  • Expert 50 Answers
  • Posted on Mar 10, 2009
Jim Brauer
Expert
Level 2:
Answers
50
Questions
Helped
18387
Points
108
Bind the IP address to that port UDP or TCP (or both..your preference) #5060 in the forwarding section of your router. check the box to enable it. Click APPLY or OK or NEXT...wait for changes.
WAG 200G getting pop up asking for network password, how do i get rid of pop up ?
When you enter your credentials check the box that says save my credentials.
I have broadband cable service. My cable modem ic connected to a Linksys Dual band wireless router. My computer is then connected to the wireless router on USB port 2. My Link sys VOIP is connected to the...
First unplug your router, then unplug your modem and for 10 seconds. Next plug the modem back in and wait it to reboot(on mine this a series of 4 lights that light up in sequence, when the 4th light stops flashing, reboot is complete). Finally plug your router back in.
3answers
Wireless webcam behind dsl modem/router and a wireless router
What you have to do is ,first covert the modem into bridge mode, then configure the router in pppoe modem by having internet username and password from ISP .. that will resolve your problem
2helpful
4answers
Linksys WAG200G
OK the main problem right now that the only data carrier in Saudi Arabia (STC) is upgrading its infrastructure to provide high bandwidth to end users. STC is using Huawei MSAN which doesn't support linksys.
Here is a firmware update which they say it will overcome some of your problems.
Mirror1
Mirror2 - rapidshare.com
Mirror3 - Google Groups
here is the link for the original article in Arabic
Xbox Live Can't Connect to Friends
Hi akemccarthy
you may need to open the ports for the linksys Router aswell
because the linksys links the belkin to the internet there using a shared connection
once youve fowarded the ports properly check to see if you have enabled the UPNP on both of the routers if they have any
heres a website showing how to port forward the ports you need opening
http://portforward.com/routers.htm
Router does not hold the internet signal effectively
Can you please tell me whats the current Wireless Mode? have you perform reset?
Port Forwarding for Transmission
This web page has a wonderful graphic step by step to use port forward for your linksys router:
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/default.htm
Hope this helps.
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
http://www.portforward.com/english/routers/port_forwarding/UTStarcom/UT-300R2U/Vonage.htm
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
My RCA router needs to be port fowarded
Go to this page: http://www.portforward.com/routers.htm Find your router on this list and it will give you a detailed description on how to port forward.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
