I cannot set my fax machine to allow incoming calls to go to the answering machine. The fax picks up the call and sends the dial tone through the answering machine. How do I set the fax machine to pick up a fax and the answering machine to pick up a missed call?
Try This:
http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000239/T8_UG_US_1.pdf
Hope it helps
I can not recive any fax at all
To make sure the printer picks up
incoming faxes, set Auto Answer to On, and then set the printer to pick up
after a greater number of rings than the answering machine. For example, if the
answering machine picks up calls after four rings, then set the printer to pick
up after six rings. This way, the answering machine picks up calls first and
your voice calls are received. If the call is a fax, then the printer detects
the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the
same telephone line if you subscribe to a distinctive ring service offered by
your telephone company. This feature allows you to have multiple telephone
numbers on one telephone line. Each telephone number has a designated ring
pattern (single ring, double ring, triple ring, or double and triple ring). The
different ring patterns let you know which telephone number was dialed, and
which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
expecting a fax.
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
