Check the following while running the engine, with coolant topped up:
The plastic reservoir bottle could be cracked check for leaks.
One or more of the hose-clamps aren't sealing well enough.Re-tighten or replace.
The radiator cap seal is torn or broken this would be obvious by steam and/or sputtering water at cap level.Replace cap.
The radiator might have sprung a leak or rusted through.Repair or replace radiator.
The cooling hoses may have perished.Replace.
Check around the water pump as one of it's seals or bearings me be worn out.Repair or replace.
Hope that helps! Good luck!
