When turned on with new batteries and new ion pump sensitivity goes to max.
A great metal detector is that which is easy to use, lightweight and can detect objects to great depths. Therefore, it is easy to eliminate lots of digging when using such a detector. I had a problem looking for such a detector. I was embarrassed by my first two or so detectors and as such, embarked on in-depth research. Bounty Hunter QD2GWP Quick Draw II Metal Detector Review
YOU HAVE PROBLEMS WITH THE ANTENA PROBE , PROBLABLY THE METALIC TERMINAL THAT MAKE CONTAC WITH THE ION TIP IS OPEN CK IT , YOU CAN SOLDER IT AND PUT BACK THE INSULATION AT THE SAME POSITION
