The ringer doesn't ring
Since you didn't specify the model of your Uniden 2.4GHz phone I can only suggest you select it from the list beginning here to download a copy of the manual.
SOURCE: Taking off Do Not Disturb
For GE 6.0:
There is a button on the base lower right corner (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
1. Pick up the phone handset and dial *98.
2. Press 2 to disable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Hope this helps!
take the battery out for a few minutes, and see if it clears.
Hope this works for you
Ed
SOURCE: My uniden powermax 5.8 ghz set itself to Do Not Disturb.
The do not disturb feature (DND) allows you to mute the ringer, the base, and any registered handsets at the same time. The phone must be in standby mode. Press and hold do not disturb on the base. You will hear a confirmation tone, and the DND LED illuminates. To cancel the DND feature, press do not disturb again. You can also mute the ringer tone while the phone is ringing by pressing do not disturb on the base.
Activating the DND while the answering system is off will turn the answering system on automatically. The answering system setting will reset to the original setting when you cancel the DND.
If you press answer on/off when the DND and the answering system is on, both of the DND and the answering system will turn off.
To mute the ringer tone temporarily for each handset or the base, when the phone is ringing, press the MUTE soft key on the handset or the base. The ringer tone will return to the previous setting starting with the next incoming call.
SOURCE: Please tell me how to turn the phone ringer back
Pick up the handset.
Use the volume up and down key to pick the ringer volume level.
Your ring will come back
SOURCE: Ringer does not ring on one phone
Well it depends on the model, Most of them you can adjust the ringer volume by pressing the volume up key while the handset is onhook (not in use)
