Batteries aren't charging up. On the charger when it is plugged in shows a bright white light in the number 2 section and a green light on the end. Why is it not charging?
That`s most likely your problem. When left uncharged for that long of a period,the batteries will discharge below 12 voltDC. The charger only recognizes 12 volts and up. So the charger can`t bring your batteries back up over 12 volts. You will need to get them on a slow charger,like a car charger or have them replaced. If you know someone or have a voltmeter,set it on DC and check each battery. If it is below 12 VDC,they need to be put on a slow charger or replaced.
Clarification:
dromtrnpa
yes there was a point in time that I left it unplugged as long as a month.
dromtonpa
Thank you very much for your time and cooperation. You were very
patient and cooperative.
Was there a point in time when you left the chair unplugged for more than 4 or 5 days?
