Hi
I am assuming your machine grinds, then clicks twice, then the brew drive starts but you never hear the pump.
If this is so? The there is a lever at the top center of the door on the right. Pull the lever back 1 click, and try again.
Run CLR through a couple of cycles and flush with clean filtered water through a couple cycles. Try to use filtered water to prevent lime and calcium buildup, besides, the coffe will taste better - Godd Luck-Ned-
Try open for steam, it could be that there`s an airbubble inside the fluidsystem. Or maybe check the manual if ypu need to empty the system after using the steam, I know some older models has to be ventilated after the steamprocess.
what kind of recipe do you want to know.Cappuccino is Made from Latte and Coffe.Sturbucks is not Cappuccino..Originally the name cappuccino came from COFFE(BLACK) AND MILK(WHITE).Both togheter give the color called CAPPUCCINO.In so many years the cappuccino found different way to make it work....caramel,coccoa,nutmeg....The good recipe and famus still the regula cappuccino with sweet or unsweet coccoa on the top of the foam.
Hi
Do you get a short pump sound and then the grounds or does it try to brew (30 seconds) and can't
This sounds like a water flow problem. Does the water come out the steam dispenser when the knob is opened?
