Outlook Express is using a French dictionery to check spelling prior to forwarding emails. I am using version 6 with Windows XP service pack 3.
If you go to Tools/Options/Spelling the only language available is French.
I have checked Microsoft word and it is still using the English version.
The problem appeared at the same time that I down loaded the trial version of Microsoft Office 2007. Possibly only a coincidence.
Open Outlook Express, click on Tools>Options and the Spelling tab. At the bottom is the dictionary that is being used. You can change it to English...
Please rate this solution
Here is a website that addresses your issue, in fact apparently its a common problem after downloading office..
http://www.outlook-tips.net/archives/200...
All settings for date time language and region are still correct. Language tab is still english. The problem only seems to be limited to out look express
Thank you for your suggestion, as indicated in my problem I have tried this and the only dictionery available is French.
Check to see if you regional and lanquage settings got changed. Go into control panel>select date, time, lanquage, regional settings. On lanquages tab see if it is still english.
