The light controller doesn't come on for a while, then flashes on and off. The fan works properly. I've installed 2 other used controllers and switches and all 3 work the same way (1 of them used to work properly). How do I find and fix the problem?
SOURCE: dual-switch controller was installed by
Sounds like it needs to be repgramed, but it may not be in the switch, maybe in the lamp/fan receiver (sounds like the wireless one), if this is the wired version, you may have to check all connections to make sure they didn't come loose.
SOURCE: I tripped the breakers to
Do other things on this circuit work??? Are you sure that the circuit breaker reset and it is on again....
Sometimes the power off and power on cycle will surge the dimmer enough to kill it...
I would get a meter and make sure you still have power at the switch...
heatman101
