Stanley 1800 PSI 1.4 GPM Electric Pressure Washer with High Pressure Logo
A
Anonymous Posted on Apr 14, 2013
Electric pressure washer will not turn on
I plug the pressure washer in and the light on the plug is red. I have tried to reset and it stays red. The motor will not turn on.
P1800s power to the pressure washer. moter does not come on
When the power washer does not turn on, it is either due to no water flow or no electricity going to the power washer. In other words, either a water or electrical problem.
check water flow issue like this
  1. The high pressure hose, spray gun and lance must be connected to the power washer.
  2. The garden hose must be connected to the power washer using the garden hose adapter.
  3. Turn the water completely on at the water faucet.
  4. The power cord should not be plugged in.
  5. Squeeze the trigger on the spray gun.
  6. If there is water flow through the spray gun and lance shooting 10 - 25 feet, this confirms water flow is NOT the problem for the power washer not turning on.
  7. If there is no water flow, perform the following troubleshooting procedures:
    a. Remove the lance, squeeze the trigger. If water flows, the lance is blocked. Use cleaning wire to clean the nozzle tip and try again.
    b. If no water flows with lance removed, turn the water off. Remove the spray gun from the high pressure hose. Turn the water on, if water flows, the gun is the problem. Reattach the gun, turn the water on and squeeze the trigger. Sometimes this unblocks the gun. If not, replace the spray gun.
    c. If no water flow with the gun removed, remove the high pressure hose, turn the water on to make sure there is no blockage in the hose. This is very unlikely but we need to make sure.
    d. If no water flows out of the water outlet, the quick connect garden hose adapter is problem. See Garden Hose Adapter troubleshooting.
  8. For electrical solution check
  9. The power switch was not turned on. Find the power switch and make sure the "-"side of the rocker switch is pushed down. "O" = Off and "¾" = On.
  10. Next, make sure the power cord is plugged directly into an outlet and NOT into an extension cord. The directions do say not to use an extension cord.
  11. Each time the power cord is plugged in to an outlet, the Reset button on the GFCI module must be pressed down to connect to electricity.
  12. Check to see if the Reset button has been pressed.
  13. Next, confirm the small plastic window below the Reset button shows RED in the window. The RED color is not a light but a RED screen that slides into the window when the Reset button is pressed down. Because it is not a light, it can be hard to see in low light. If you are unsure, press the TEST button down. If the GFCI was set and RED was in the window, you will hear and feel a "click."
  14. The RED color must stay in the window once the button is released. This confirms there is electricity going to the power washer.
  15. If the RED color goes away when the Reset button is released, there is NO electricity going to the unit. Try another outlet until the RED stays in the window.
  16. Now if the unit turns ON for a second or two with the Reset button pressed and the power switched on, it is working as it should. All that is left to do at this point is to squeeze the trigger on the spray gun and the power washer will turn on. When the trigger is released, the power washer will turn off. This is due to the Total Stop System (TSS) that only turns the unit on when water is flowing through the power washer. When the trigger is released, water flow stops which the TSS sensed and immediately shuts the unit off. a) So to review, if the Reset button has been pressed and is holding and the power switch is ON, the power washer is supposed to start up for a second or two and immediately shut off. At this point all you need to do is squeeze the trigger; the unit will turn on.
Oct 24, 2019 • Garden
When I plug it in the red light on the reset switch and keeps throwing the reset to off after I reset it
It's hard to fully understand what your issue is but I am guessing when you connect water supply upto your washer and have it plugged in then switch it on the machine trips out on its overload switch !!!
If this is your problem and you know the machine has power then your looking at the machine having an electrical overload, this could be due to a few things, with all electric and water disconnected some where on your machine should be a cooling fan that is attached to the motor and that is behind all the plastics. There should be an opening some where so you can use a screw driver to try and make that fan blade type thing spin, you should have some resistance it's not free spinning, if it does not turn at all your motor is sized. If it turns then you will need to take apart the machine so you can get to the electrics. Try this first
1helpful
1650 husky pressure washer starts and then stops
If you are not squeezing the handle to let the water out, it will shut off.
Nov 30, 2013 • Garden
McCullock Powerwasher FHH18A - All hooked up, but pump won't turn on. Is there another switch/button somewhere?
look for 2 things. 1. the GFCI button on the plug, you may have to press the 'reset' button to turn it on. 2. there may be a reset button on the motor or the unit somewhere this will usually be round, and often red, but maybe black also. hope this helps
My electric pressure washer's motor will not start. the 110 plug has a test/reset fuse on it. when i plug it in the light comes on. i push test- it turns off but motor does not run. i push reset and...
With the water faucet turned fully on and the power switch on squeeze and hold the trigger for at least 10 seconds to let the water flow push the air out and then it should start up.
Wont turn on , light on plug will not stay on after release of button
most likely faulty switch. Use licensed repairman for electrical hazard.
3helpful
Red light on power cord stays on powerwasher wont turn on
The red light means you are getting power. It sounds like the bypass (unloader ) valve is stuck. This is inside the actual pump
Reset Button
your testing the no fault short or motor overload feature. the red light indicates you have power. no light no power.
Top Stanley Garden Experts
ADMIN Andrew
ADMIN Andrew
goneforever.
Stan Ford
Are you a Stanley Garden Expert? Answer questions, earn points and help others
