Connect light cables to harddrive
Schematic
The eMachines T6532 uses an MSI MS-7207 motherboard.
Also known as the KN8GM2-L,
http://www.msi.com/product/mb/K8NGM2-FID--IL--L.html
[ http://www.newegg.com/product/product.aspx?Item=N82E16813130041 ]
The MSI motherboard has provisions for using, EITHER an
IDE (PATA) harddrive, or a SATA harddrive. (Or more than one)
Two different technologies.
I will explain both, using an IDE (PATA) harddrive,
OR;
Using a SATA harddrive;
On the MSI Support page above, click on the Download tab.
(Overview / Specifications / Download / Support / etc)
In the drop down list click on - Manual
Language > English > 7.1MB > E7207v2.0.zip
Click on the blue E7207v2.0.zip
On the next page click on the country name nearest yours.
A small window will come up -
Opening E7207v2.0.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
IF not; Left-click in the small circle to the left of Save File.
Now go below in the small window, and click on OK
A small download window will come up. Allow the file to download ALL the way, then DOUBLE-click right on it.
In the next small window go to the far left, and click on -
Extract all files.
At the bottom of the next 3 small windows, click on -
Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name.
(7207v2.0(G52-M7207X5) next to the red Adobe PDF icon)
There is the Motherboard Manual
The MS-7207 has two IDE slots;
IDE 1, which is Yellow in color, and close to the outside edge of the motherboard.
Should have IDE 1 silkscreened on the motherboard, below it.
IDE 2 is Yellow in color also, and right next to IDE 1.
(IDE 2 is in-between IDE 1 and the Ram Memory slots.
The Purple, Slot 4, ram memory slot to be specific. {DIMM 4 )
IDE 1 is used for an IDE harddrive.
IDE 2 is used for an IDE optical drive.
TWO IDE harddrives can be put on a single flat ribbon IDE cable,
http://en.wikipedia.org/wiki/File:ATA_cables.jpg
NOTE that there are two styles of IDE flat ribbon cables;
40-wire cable,
OR;
80-wire cable.
BOTH have 40 socket holes in their connectors.
(ONLY 39 are used, so one hole May, or May Not be blocked off)
How to connect to a 40-wire IDE cable, or an 80-wire IDE cable,
http://www.mikeshardware.com/howtos/howto_connect_ide_hd.html
An IDE cable usually has a Locating Lug on it's connectors, in the middle of the connector; and on one side,
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
Here you see the Locating Lug as being two separate 'ridges'.
Some styles the Locating Lug is single block.
The motherboard connector has a matching Cutout on one side.
The Locating Lug lines up with the cutout when installing the cable.
The Harddrive, and optical drive (CD/DVD drive), will have a cutout on their circuit boards.
There are 40-pins. (Only 39 are used if so)
One of them is the number 1 pin.
The IDE cables are plugged into the motherboard, with number 1 pin lining up with number 1 wire, in the IDE cable.
Same when the IDE cable is plugged into a Harddrive, or optical drive.
IF, there is no Locating Lug on the IDE cable;
Look for the faint RED stripe, on the side of the IDE cable.
Number 1 wire is on the same side, as the faint Red stripe.
When plugging into a motherboard, Number 1 pin is on the Bottom.
The faint red stripe on the cable, goes towards the BOTTOM of the motherboard.
(Motherboard installed in computer case)
When plugging into a Harddrive, or optical drive; the faint red stripe ALWAYS goes toward the power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
This shows you the Back of an IDE (PATA) harddrive, and the power cable used for it.
If -> No Locating Lug on IDE cable, the faint Red stripe goes towards the power cable.
This is a 4-pin standard Peripheral power cable.
Note when installing the rounded corners ALWAYS goes UP.
[This power cable is frequently, and erroneously; referred to as a 'Molex' power cable.
Molex was just the first manufacturer of the power cable CONNECTOR. Name STUCK.
Kind of like calling an adjustable open-end wrench, a 'Crescent wrench ]
A SATA power cable is used for a SATA harddrive, or SATA optical drive,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
There is an L-shape in the SATA power cable's connector.
It matches an L-shape on the Harddrive, or optical drive.
Between a SATA power cable's connector, and a SATA data cable's connector; a SATA power cable connector is the LARGER of the two.
A SATA power cable has 15-contact pins.
A SATA data cable has 7-contact pins.
A SATA power cable's connector may have a LOCK on it.
Usually a Tab, or 'bulb' type affair.
It is pressed down with the thumb when installing, or removing the SATA power cable.
This is a general example of a SATA data cable,
http://en.wikipedia.org/wiki/File:SATA_Data_Cable.jpg
Now you can see the L-shaped opening a little better, that both the SATA data cable have, and the SATA power cable, has.
In the photo the SATA data cable's connector, is a 90 degree bent Elbow.
This style of connector is usually used on the Harddrive, or on the optical drive.
A Straight connector style is usually used for the Motherboard.
However, you can use a SATA data cable, that has a Straight connector on both ends.
Looking at your motherboard, installed in a computer case; there are 2 SATA connectors on the motherboard.
(CAN, be up to FOUR)
I see one motherboard reference where they (2) are Orange in color, (Newegg), and the motherboard manual shows them (2) to be Purple in color.
They are located towards the Bottom/Right corner of the motherboard.
Above the CMOS battery.
The SATA connector that is closest to the Outside edge of the motherboard, is SATA1 (SATA 1)
The Harddrive plugs into SATA 1.
An optical drive that is SATA, will plug into the SATA2 connector.
To the Left of the SATA1 connector.
KNOW THIS;
DOES NOT MATTER, which SATA connector you plug the Harddrive, or optical drive; into.
The beauty of SATA, is that you can plug the Harddrive or optical drive into ANY SATA connector, (On ANY motherboard), and BIOS will find those devices.
BIOS looks FIRST, to see which drive has the Operating System on it. (Windows)
THAT, is the Harddrive.
After finding the drive with the O/S on it, then BIOS will find all the other drives. Removable, or not.
So there you have it. A lot of reading.
You need a power cable, and a data cable to the Harddrive.
Same thing for the optical drive/s.
To have me clarify anything I have stated above, please post in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
