My car was totaled. The Kenwood stereo was removed and my favorite cd is stuck inside. Can I get the CD out without reinstalling the stereo in another car?
SOURCE: GET IPOD TO WORK ON KENWOOD KDC-W3037 CAR CD PLAYER
you have to activ ate the aux port form the menu, on standby hold the menu button and then use the control knob on the right to change the aux to on1
SOURCE: Car Stereo in Protected Mode will Not Play Radio or CD
try the small reset on the lower right hand side of the player it fixed mine
SOURCE: MY KENWOOD CAR CD PLAYER IS SAYING PROTECT??
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
Thanks,
SOURCE: I have a Kenwood KDC 135 car stereo wont un mute.
behind the face plate there is a little recessed reset button. push it using the tip of a pen or similar. that will fully reset the radio to like it was when you bought it.
Some times head units hicup. this is how you reset it. In most error cases this solves the problem.
SOURCE: how can i deactivate the protect that blinks in my
Disconnecting the terminal will take to much time.. In between the skip button ,and the #1 on your stereo there is a little dot. Barely noticable unless you know what your looking for, take a safety pin or a screw( anything with a little tip) and push it in. This will restart your stereo. (Car Must be on)
