Manual number JBP24BOBSWH and serial number HF2 12067Q
You will need to replace the oven control on the unit. Here is that part to order. All parts come with a 365 day, any part, any reason return policy.
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak. You can look at it and see how it compares to the broil ignitor. If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
SOURCE: GE Spectra stove, oven won't light
Hi ewood,
You can look up your ge owners manual at ge.com . If the oven has stopped working chances are you have a bad ignitor. the part number is WB2X9154 . The part is $69.99 and I have this item in stock. Shipping will be $6.50 in the continental US>
I hope this will FixYa. If you have more questions please let me know. I can tell you how to remove the old ignitor if needed.
Anderson Appliance
Mike Anderson (Owner)
(865)945-3808
SOURCE: The oven on my GE Spectra JGBP35 will not heat up.
i would bet your ignitor is bad
goto appliancepartspros.com
type in your model; do ignitor search
it wiill show you a picture of where it is
you will want part number
AP2014008 runs around 62.00
SOURCE: The oven does not heat up on my GE Spectra XL44
Might be the bottom element is bad. Not too hard to install a new one.
I am no electrician but if you unplug the stove, remove the bottom element and use an ohm meter attatched to each end, it should show if the element is broken through lack of continuity.
Just an idea from a landlord.
