It sounds like you have a print job stuck in the print que. When this happens the print jobs after the stuck one will not print either. You will need to clear the print que and reprint the jobs. Here is a link to an article showing how to purge the print que and get your printer back printing again.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
SOURCE: Lexmark 1200 series printer won't print
Call me and I can walk you through what Lexmark just walked me through with the same problem
Laurie
732-356-7256
SOURCE: Lexmar Z611, How do I delete 20 items in printing queue?
Goto Start click on Run type in Services.Msc and hit ok.............. Now on that list select the one which says Print Spooler right click on it and click on Stop........ Now go to Run again type in Spool and Hit Ok............ on that window click on Printers....... Delete all the items under Printers............. Close that Window............. Now Right click on the Print Spooler and click on Start............. Now Uninstall the Software........... Download the Drivers from the website............Install the Downloaded drivers....... It Should work............ Thanku
SOURCE: printer in queue, need to print
It could be a print job that has stalled.
Open the print queue (on the taskbar by the system clock)
and cancel all the documents that are there ,then reprint and see what happens.
Also make sure the printer is plugged in and online.
SOURCE: I just installed a new system Windows7 and Home
What you can do here right now is to clear any print queue , to do that follow this procedure.
Click Start then go to programs then accessories then go to system tools and then look for Command prompt , then right click Command prompt and click RUN As Admin then once the black window is open type there NET STOP SPOOLER and hit enter and once the process is done type this next command NET START SPOOLER and hit enter that should clear any print queue and now try to print.
SOURCE: printer won't print. I
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the
print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\
folder. You should see files there ending in .SPL and .SHD created around the
time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the
Try to print a document again to verify that the problem is fixed.
In the Print Queue toolbar you have these buttons:
