I WANT TO GET THIS USER MANUAL
SOURCE: sony model # kv-36xbr800
The standby light should be blinking a repeating count with a 2 second pause between counts. Can you post hte count here please? That will help to determine the effected circuit and the solution.
Thanks,
Dan
SOURCE: I have a Sony Trintron KV-PG21P40. When I'm
Since the set recovers under some conditions, I would first look for poor solder connections. With a set of your vintage, it is common for some of the connections to become faulty. If you can solder, resolder any connections on the board that appear grainy or have rings. Please note that there are potentially dangerous high voltages present inside the set even when unplugged.
Keep us posted on your progres.
Dan
SOURCE: NEED OWNERS MANUAL FOR REPROGRMMING CHANNELSKV2185P
I didn't solve problem Ineed a owners manual for sony trntrn tv kv2185p
SOURCE: i am looking for a user manual online for a sony
you might see if Sony will send you a manual.
Call 1-800-222-SONY (7669)
or
http://esupport.sony.com/perl/select-system.pl
in this link u ll find the required manual
SOURCE: I have a Sony Trintron also - similar model to the
looks like a horiz.output transistor is shorted.check it...
