Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Burners and oven will not turn on
Clock works, but burners and oven will not turn on.
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
You will need to replace the control board. Here is that part to order.
Posted on Apr 15, 2013
4 Suggested Answers
6ya staff
SOURCE:
KOakaKO
Kevin Omel
  • 135 Answers
SOURCE: Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Posted on Aug 09, 2007
guptamdr
SOURCE: Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Posted on Sep 13, 2010
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: the oven and burners do not work yet the clock works
It sounds like you may be missing part of the input voltage at the wall receptacle. You should be reading 220-240VAC across the two hot terminals (left and right slots) on an ELECTRIC range. Some homes are wired with two separate breakers to make up the 220 service that feeds your appliance. If this is the case, make sure one of the breakers is not tripped.
Or, you may have a possible bad power cord. With the unit unplugged, check the continuity of the power cord from end to end to make sure the wires are not broken.
The clock assembly functions off of a 110-120VAC source which is tapped off the input voltage. All the elements (including the oven) all use 220. If one of the input legs is missing, the clock will still function, but none of the elements will work. Please check and get back to me if this isn't the problem. I hope this helps you.
Posted on May 31, 2010
Oven does not work/ clock does not work on frigidaire fef353bfwe range. burners work, but no oven or clock readings. oven won't turn on, but light works.
sounds like you've lost 1/2 of your 220vac...try reseting breaker...sometime one side will trip and not the other
Feb 21, 2010 | Kitchen Ranges
Thanks
Jan 06, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Maytag65300ddS My burners wont turn on,. Clock
Sounds like an open connection between the supply circuit and the burners. Could be corroded, burned, broken, or just loose. Also could be a bad/cracked resistor in the same circuit.
I suggest a service call.
Apr 21, 2009 | Maytag MEW6530D Electric Single Oven
Whirlpool Electric Range Model RF379LXMT0 Power was off in house overnight and back on. Burners work but oven and controls for oven, timer and clock don't work.
I turned off the breaker switch for about 5 minutes
and then turned it back on. Now the oven, timer
and clock etc, are working again.
Thanks You
Aug 07, 2008 | Whirlpool Kitchen Ranges
Burners and oven wont get hot and light wont come on
The input power is incorrect. The neutral connection may be missing
May 22, 2008 | GE Profile JTP18 Electric Single Oven
Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
Jan 14, 2008 | Jenn-Air JES9860 Electric Kitchen Range
No heat at burners or oven
check your fuse / breaker box make sure you have power (sounds like you dropped a leg of power) make sure breakers/fuse is on/good flip it to off the to on if oven don't work then take a look at the cord to the range check power at the wall then open where cord goes into range check power or you may even find the cord burnt in there if so replace all damaged wires good luck
Dec 21, 2007 | GE JBP82 Electric Kitchen Range
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
260 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
