Sharp Aquos 32 inch LC-32LE340M LED Multisystem TV FOR 110-220 VOLTS Logo
Posted on Apr 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot power on
Standby light not lit up
Level 3:
Top Expert:
  • Sharp Master 76,851 Answers
  • Posted on Apr 14, 2013
Sharp Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14996046
Points
237762
The problem you've posted here haven't enough details to provide a solution. Give more details please. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
1helpful
1helpful
Lcdx37whd88
Sounds like your power supply capacitors have failed. Google for Z1234TV and see if you can locate a power supply capacitor repair kit for your model.
My Sound Space12 powers on but there's no display and no manual or remote functions to operate the discs or the other functions.Can you provide a answer.regards
If the system is connected properly and the main tuner power is on you will see the orange standby light on in the front of the main diamond shaped control unit. If that light is not on, you have not connected the system and power cables properly.
If the standby light is not lit, press the power on/off button in the middle of the rectangular processor/tuner to turn it off and unplug the main power cord from the main tuner/processor from the wall. Next, ensure that all of the power, video and audio cables from the diamond shaped control unit are properly connected to the large tuner/processor. Since you are there, check any other av in/out connections.
Now that you have checked and adjusted the cables between the controller and the tuner, plug the tuner back into the wall and push the power on button. Now check the standby light again on the diamond shaped controller unit.
Once that light is lit, press the silver, horizontal on button in the middle of the diamond shaped display unit, or the Power Standby/On button on your main remote control and you are operational.
NO PIC-NO AUDIO
No standby light up front= Main Board. Standby light lit but wont power up = Power supply board.
2helpful
Element stuck in standby and wont turn back on.
you can unplug the power cord and drench the power and after go ahead and plug in back the TV and try to start it
3helpful
2answers
NO POWER ON THE TV SANSUI PLASMA SV EPD 4230BP .IT HAS TRIPPED THE ELECTRICITY.NOW THERE IS NO POWER ON THE PLASMA TV WHICH IS 42 INCH.
If you have a power cut when tv is on - it shuts down for safety - leave it for 1 hr or overnight - then it works!! I have a UPS as our power here in Mozambique always goes out
1helpful
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Flashing light - video going out
When you push Power Button on remote, TV goes to Standby state i.e its power light (LED) lit but no picture / no sound. Power button on remote has symbol looks like.. ( ! )
37FD9954/17
hi, i have read somewhere that you need to replace both 100u / 25 caps aswell.
the info came from a user on here called PaleFace but i cannot find the original post now and i have the same problem with my tv.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
