Stick your key in the ignition and turn to start. That should stop the alarm. However, it sounds like your battery still isn't fully charged. Computer things go haywire when battery voltage is 9.6 volts or less.
Either the charger or the battery is faulty, from the sound of your fault description. If the tablet will turn on and run normally when the charger is plugged in, then the problem most likely lies with the battery. If it will not run even when the charger is on, then the charger is most likely the cause of the fault. If your tablet is still under warranty, either problem should be repaired free
The internal cells are worn out and will not accept a full charge.
A full cell replacement is required.
All batteries are an expendable, they are chemical based and degrade with time.
normal life expectancy for any battery pack is 3-3.5 years at better than 60% use them or not
I can Re-Cell any Anton Bauer Battery Pack and many other styles and makes. Website: ritterbattery.com or contact me direct at: [email protected] Phone 954-557-9765
The Dionic 90 series batteries will last between 2-3.5 years or about 200-250 cycles (at 60% or better of original capacity) At this point they can be recelled (install all new internal cells) cost is a little less than half of a new battery purchase.
Another common problem is loose or broken connections which will render a battery pack useless or dead, this can be easily repaired if caught early on before the cells self drain and go bad.
I specialize in repairing Anton Bauer and other professional video application batteries.
discharge your batt. fully. charge your batt. on 3phase current. dont remove in middle, give time for your batt. to charge fully
ues JVC original batt.
