Question about Pride Mobility Revo 3 Wheel Electric Scooter Floor Sample
Pride revo the green light flashes 9 times will not go
Will not go light flashes 9 times
SOURCE:
FixinFax
  • 3085 Answers
SOURCE: Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
Posted on Jun 18, 2009
  • 17 Answers
SOURCE: Need Wiring chart for Revo 4 Pride Mobility
I have wiring chartfor Revo if your interested
Posted on Nov 09, 2009
gewiz
  • 1367 Answers
SOURCE: need wirirng diagram for batteries, pride revo
hi,
look at page 25, it contains a basic layout for the batteries.
http://www.pridemobility.co.uk/docs/UK_Revo_om.pdf
Please vote if this helps.
Regards
GeWiz.
Posted on Jan 06, 2010
  • 63 Answers
SOURCE: revo pride 2 year old
Well I hope I can be of Some help, If the batterys on a scooter are not charged daily after use they will deplete, in other words loss there power/charge.so each time you miss a charge the batteries will start lossing there life expectancy.that is why it Is very important to not miss a charge.When your batteries dont take a charge, that's basically saying you need new batterie. One way to make sure Your batteries need change and not your charger .... First trickle charge the batteries Second install the batteries back on the scooter Third plug in your charger it should kick on Good luck
Posted on Feb 11, 2011
  • 118 Answers
SOURCE: NO DRIVE ON MY PRIDE REVO MOBILITY SCOOTER
You can try to do this with the cover off, just in case it is not seated properly and holding the lever from fully engaging. The actual swithc is a small microswitch down at the brake, and it can get dirt in it and that will stop it from working, or it may even fail, and need to be replaced. So I would:
1) try it woth the shroud off the motor using.
2) look for dirt around the switch.
3) take a paperclip and jump the scooter side of the switch to bypass the microswitch on the scooter, be careful not to short the jumper to the scooter frame.
Let me know how you make out.
Dan
Posted on Jun 11, 2012
Status button flashes 5 times. Scooter is fully powered but will not move. Brake is off, lights work, etc.
BEFORE U RING TRY THIS TAKE KEY OUT PUT FREE WHEEL LEVER IN FREE WHEEL THEN PUT IT IN DRIVE PUT KEY IN & TRY OT. Hi again get in touch with pride www.pridemobility.com or ring them 1-800-800-8586. They might B ABLE to help cheers if the electronics r the same as celebrity put freewheel lever in drive & remove key then :::: put it back & try it out good luck
Apr 18, 2016 | Pride Revo 3 Wheel Scooter
Where is the controller on the revo 3 wheel scooter? Fault ( 9 )
hi , that 's is a internal fault, most likely a bad connection to the controller, at worse it 's a fault with the controller.
Regards
Rob
www.gewizrepairs.co.uk
Jun 25, 2014 | Pride Value Line Revo Scooter 3 Wheel
How do you takshroud off the motor of pride revo?
You are almost certainly going to have to lift the seat off its post as you do with other Pride scooters. This is not light and it can be sticky and need tobe wiggled off - get help.
The shroud is usually velcroed into place and can easily be detached. Lift it off and put safely to one side.
Jun 21, 2014 | Pride Revo 4 Wheel Scooter
Green light flashing 9 times
sounds like you are sitting on some of the wiring or connectors, take it apart like you did to fit batteries and check there are no wires shorting out or connector is being squashed, check as you put it back together, you should sort it that way. the error code should be:
9 BARS: The parking brakes have a bad connection or have a failed solenoid, or any lever or switches that disconnect drive for pushing the chair manually may be pulled or switched.
so check these wires and connectors closely first.
but please note that with out the make and model the error code is the most lightly posability.
Nov 26, 2013 | Pride Mobility Products Health & Beauty
I need a replacement power cord for the 3 wheel Revo scooter. Where can I get one?
The AC power cord is a standard cord used on computers and a number of other electronic devices. They can be purchased at any Radio Shack for about $9. If you have the old cord, bring it with you to match up for the new one. If you don't have the old one, draw a picture of the cord receptacle and bring it to the store. I describe the wall side as a three prong grounded plug and the Revo side of the cord or charger side as a trapezoid shape receptacle. See the link to Radio Shack for the complete picture:
http://www.radioshack.com/product/index.jsp?productId=3875423
Hope this helps.
Mar 19, 2011 | Pride Mobility Products Victory 9 Scooter...
Will not go know & the status light is flashing 7 times
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Oct 31, 2010 | Pride Value Line Revo Scooter 3 Wheel
Jun 03, 2009 | Pride Value Line Revo Scooter 3 Wheel
Pride Mobility Revo 3 Wheel Electric Scooter Floor Sample Logo
114 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
