Sprayer is clogged and won't spray
SOURCE: The sprayer nozzle is stopped up, i have tried
Dear Ishleor,
If the nozzle on your sprayer is metal you can use CLR (Calcium Lime & Rust remover) to break up the clog. If the nozzle is plastic you can use a sewing needle to clear the clog.
Yours Sincerely,Coach Dave
Round up 1.33 Gal Spray can have a bad pump or a clogged filter or both.
Test pump: pump the handle, does it get harder to pump after 10-15 pumps, when you open the cap does air rush out? If yes, pump is good, if not, wear rubber gloves, remove pump/cap assembly, remove inner tube from cap, the handle\ pump plunger will remair with the cap. if the o ring is dry, wipe it clean, put a little petroleum jelly on the plunger o ring To Lubricate it and prevent o ring wear and helps it seal air tight so the pump will work correctly. reassemble handle\cap make sure the Black inner black plastic hose aligns with the white spray hose .
If your pump passed the pump test, lool inside tank at the chemical fluid clean or does the fluid look like it has lumpy white clumps in the fluid, if so, empty fluid in tank into a clean throw away container look at rinse the tank out with water, strain the clumps out with a paper towl draped over the tank opening inserted about 2 inches into tank opening then when you slowly pour the fluid back in hold both end of the paper towel so it does;nt fall in tank the clumps will remain on top of the paper towel , Then your ready to clean the filter in the cap. Remove the black plactic tube from the pump, remove the white out side hose(squeeze the black connector to unlock the white hose , Then look in the hole the the black tube was inserted into, look for clumps (looks like lint from a clothes dryer, about the size of cotton ball, ) in that hole, to clean the clogged filter,I used low pressure air from an air tank, Blown into the hole where the white discharge hose was mounted. The clog should fall out of the opposite hole where the black tubs mounts. Reassemble and test, Also, the white spray tip turns out to change from spray to stream. Wash Hands good the chemicals can soak into your skin, some people are very allergic to the fluid
Yes, you can use Miracle-Gro Water Soluable Plant Food in the Ortho Dial N Spray hose-end sprayer. Simply set the dial on the Dial N Spray to 4 ounces. The label rate for Miracle-Gro All Purpose Plant Food is 1 tablespoon per gallon of water. To make 8 gallons of finished spray, measure 8 rounded tablespoons of plant food into the Dial N Spray jar and fill the jar with water. Mix thoroughly. Set the dial at 4 ounces. When you have sprayed until jar is empty, you will have applied 8 gallons of properly diluted spray. Hilary@Scotts
