Where the time display is it shows 'Er' the machine stops and sounds a long alarm
Tefal Actifry GH800215 user manuals GH800215
www.tefal.com/instructions.../Fryer/Actifry/Actifry.../1500634805
TefalThe Actifry Plus GH800015, GH800215 deep fryer allows you to make 1.2 kg of chips with only 1 ... To display Instructions & Manual, choose your language :.
SOURCE: TEFAL Actifry element in back has blown is it
the same thing happened to mine i think it is a bad fault mine was nearly new good luck
SOURCE: dismantling a tefal actifry to change a broken
Hi M8, External Fan Motor cover at of lid clips off first then body will split no bother at all.
SOURCE: My tefal actifry has stopped
You have just two options:-
Return the unit to Tefal for a repair under warranty, or claim under a separate product warranty.
If you have no warranty then your only fix is to replace it with another ActiFry. But as they're notoriously unreliable you might choose not to.
There is almost nothing user-fixable on the ActiFry and it has not been designed to be repaired. They have about a 3 year maximum lifespan assuming an "average" domestic usage cycle, and far less if used every day.
SOURCE: Where can i buy a replacement lid for my tefal
Try here for a lid to replace your broken one: Actifry Lid
I have the same problem but it says nothing in the manual about what to do.
Did you sort it out? If so what did you do?
the fault is that the fuse has blown behind the display. You will need yo strip it down to get to it. The cause is the motor is faulty. Replacing both items cured to fault. ( Fuse is 250ma quick blow, soldered on. and you can buy the motor from Amazon. )...Hope this helps a few of you.
