Question about Dell Inspiron Computers & Internet
CHECKSUM CANNOT MOVE COMPUTER FROM A BLUE SCREEN
A new battery was installed when I powered it up Windows XP was shown then I got a Checksum Blue Screen. I tried to open it up in every way asked but still have the blue screen with the message above.
    New Friend:
  • 16 Answers
In order to understand what a checksum error is, it is important to first learn what a checksum is. A checksum is a redundancy check during a computer's start up process, which makes sure that the computer's data is intact and unhampered. The data is scanned and tested for accuracy, either based on how well it relates to data elsewhere or based on previous data that was stored on the same computer. Essentially, all of the bits of data in a particular document or file are added up and a number or hash is created. This number or hash can then be compared to the number or hash generated from the same file on another person's computer or at a previous time on the same computer.
When does a Checksum Error Occur?
Although a checksum error can occur at any time while a computer is comparing data, it is most commonly present during a computer's startup procedure. During a computer's start up processes, the BIOS settings, which are stored in a CMOS memory chip, are computed and then checked against the previous value. If the computed values do not match exactly, the computer warns the user with a checksum error message that the data may have been changed or corrupted between start up cycles. All BIOS programs present a different error and therefore will either continue with booting or refuse to boot until the problem is corrected.
Depending on the type and the severity of the error generated, there may be one of a variety of ways to rectify the issue. The most common cause of a checksum error during the startup process is a faulty battery that is not providing sufficient power to the motherboard when the computer is off. However, motherboard malfunctions and viruses can also contribute to checksum errors.
Other Types of Checksum Errors
Another type of checksum error may occur with any program at any time. It is usual for many programs to now provide checksum information when that program is downloaded. Using a checksum program or MD5 hash checker, a user can quickly compare the checksum of a downloaded program with the checksum that the software developer provides. This is a common way to make sure that users are downloading the proper program and that no data was corrupted during the download process. Checksum errors originating from download errors can easily be corrected by re-downloading the problematic program.
if you have a windows disk you might try doing a repair from disk
Posted on Apr 14, 2013
4 Suggested Answers
SOURCE:
myob247
  • 1342 Answers
SOURCE: Blue Screen
Try re-starting your pc and tapping the F8 while it starts up and try getting in through "Safe Mode". If you can get in click "Start", "Run" and type "cmd". Hit OK. At the dos promt type "sfc" and let windows check your files.
Posted on Apr 10, 2008
  • 95 Answers
SOURCE: blue screen of death
It is a problem with either your memory manager or a dll file most likely. If you have an install disk run the memory test on it. This may be called the WIndows memory diagnostic tool or something similar. Often when it reboots it will come up fine again and keep on doing so. If its a corrupt dll you will need to repair windows using an XP system disk or recovery CD/DVD. Hope this helps.
Posted on Mar 29, 2009
nicoleFIXIT
  • 154 Answers
SOURCE: I am gettin a blue screen that says Stop c00000221
If you've encounter with this issue, this issue the same with your BIOS password you can easy access the BIOS by reset the CMOS battery and jamper.
The checksum error refer in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS. If you have the motherboard documentation, you will know where that jumper is.
If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
Posted on Dec 10, 2009
Stop c0000221 bad image checksum image
Try loading in Safe Mode and disabling as many Startup programs is MSCofig as possible. You could also try rolling back with System Restore, again in Safe Mode. From there try uninstalling any software that was loaded prior to the problem.
Another route is trying to load Windows on top of its self as to correct any corrupted files. Then try testing your RAM one DIMM at a time, one slot at a time to eliminate bad RAM.
Finally a clean install may be required, then going back to RAM isolation if occurs with a clean Windows setup.
May 28, 2013 | Dell Inspiron 1100, PP07L Series Laptop...
Checksum cannot move pc at all
A blue Screen usually means a bad piece of hardware, Remove the latest part you fitted and try again. Although The Checksum would seem to indicate a software or hard drive problem.
Apr 14, 2013 | Dell KU926 INSPIRON 1520 LAPTOP...
Booting problem
There are usually three main reasons that a CMOS Checksum Bad Error has occurred. They include:
  • CMOS Battery may not be functioning properly. The battery life may have expired.
  • Your BIOS may have been updated (either by user or possibly a virus)
  • The computer may not have been shut down properly e.g. shutting off the computer's main power without first shutting down the computer (MS Windows requires you to shut down your computer before shutting off the power).
Solutions to CMOS Checksum Bad Error The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer’s manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery’s information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue
Mar 05, 2010 | Microsoft Windows XP Professional With...
Help
Greetings,
When you upgrade your computer to Windows XP, you may receive an error message that is similar to one of the following: C0000221 (Bad Image Checksum)
-or- STOP: C0000221 - Bad Image Checksum in ModuleName
-or- STOP: C0000221 - Bad Image Checksum. User32.dll is possibly corrupt. The header check sum does not match the computed check sum.
Please go through the below mentioned link:
http://support.microsoft.com/kb/326687
Sep 20, 2009 | Microsoft Windows XP Professional for PC
My pc wont load into windows, blue screen says image kernel32 checksum
this problem could be fixed with the recovery console:
- insert the Windows XP installation cd and boot from it. - Select "Recovery Console" when prompt - type the following command:
Bootcfg/rebuild
The second (longer) option is to recover you XP installation
cheers
Jul 09, 2009 | Microsoft Windows XP Professional SP3 Full...
Blue screen of death
Mar 29, 2009 | Toshiba Satellite A55-S1063 Notebook
Dell laptop won't boot even after clean install of xp
your windows prolly crashed because your hard drive is going bad, and thats why your getting error messages when reinstalling.
Feb 26, 2009 | Dell Inspiron 1150 Notebook
Blue Screen
Apr 10, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
131 people viewed this question
Clive
Clive
Alun Cox
