Bunn CWTF 15-3 Coffee Maker Logo
A
Anonymous Posted on Apr 13, 2013
Bunn coffee maker heating element wont turn off
jasbo
Level 3:
  • Bunn Master 2,239 Answers
  • Posted on Jan 15, 2015
jasbo
Bunn Master
Level 3:
Answers
2239
Questions
Helped
991220
Points
5072
Thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
5 Related Answers
Anonymous
  • Posted on Dec 11, 2008
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
advacak
Denny Adams
  • 125 Answers
  • Posted on Dec 14, 2008
SOURCE: Bunn Coffee maker leaking out
that needs to go back to bunn for a replacement tank, they will likely only charge you for return shipping
Anonymous
  • 125 Answers
  • Posted on Jan 04, 2009
SOURCE: Bunn Coffee maker leaks
Hi, you can go to www.bunnomatic.com, and select for home or commercial units, and get an 800 number to call for service and parts. If they cannot help you a appliance repair shop should be able to get you going, thank you.
Anonymous
  • 131 Answers
  • Posted on Feb 10, 2009
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
Anonymous
  • 189 Answers
  • Posted on May 19, 2010
SOURCE: I need a wiring diagram for a Bunn BX coffee maker
I do apologize but these diagrams are not available. What is the problem with the machine? If you will get the model and code date from the bottom of the brewer and contact customer service, we can help resolve your issue. The machine carries a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, then it will be replaced at a reduced price.
Bunn b10-b neads new heating element assembly and can't find one on internet. will not keep reservoir heated.
Unfornately, the heating element is not repairable. If you will call 800-352-2866 with your model and date code, we will be able to further assist you.
1helpful
3answers
My Bunn VP17-2 coffee maker has started tripping the gfci switch when the heating element comes on. The unit is aprox. 7 yrs. Old. And has not done this before. Should I replace the heating element should...
Check the elements first, also check the hi-limit switch and the thermostat, then check the elements the machine might have been low on water at one point.
Our coffee is weaker and bland the past few days, and we are using the same amount of coffee, and the same brand, what is wrong with our coffee maker?
If this is a BUNN, the problem is the heating element is turned of by the switch on the side or the heating element is bad. Feel the rear tank area of your unit. it should feel warm to the touch at all times that is is plugged in. The water must be up to temp to work properly.
My Bunn Pour-Omatic coffee maker (White) Heat up
Most likely suspect is the thermostat, however you might want to check the limit switch also(located on boiler between elements).
2helpful
Adjusting the temperature
Our Bunn VPR was delivering luke warm coffee. The problem was lime scale buildup on the heating element. I recommend using a cleaner such as Brew Rite or a vinegar solution. If it still does not heat properly, unplug and remove the heating element for cleaning. This corrected our problem.
Bunn commercial coffee maker plug overheats, no hot water
Most likely this is your heating element, but it could also be your main thermostat
The water is not heated when I put my Bunn coffee maker on
If you plugged it in before water started coming out of the sprayhead (about 2 pots full of water poured in) you might have burnt out your element, But lets start with a simpler answer. Did you check the main burner switch on the side of the tank?
If so, then I would suspect your main heating element
1helpful
Bunn coffee maker trips the breaker
It is possible that you have a short in your limit thermostat, but most likely this is caused by small holes in your main heating element. these units start to split length ways down the element, causing a short to ground through the water. These elements are readily available at your local Bunn repair shop.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
