the on/off switch could have gone out, make sure the wall outlet is working also, could be the power cord could be the problem, the machine needs to be serviced after sitting so long.
make sure the sewing machine is not in the darning postion, some sewing machine have a sew button an a darn button,, the sew button must be pushed or the machine will not sew.
would be something wrong with the foot petal or the motor, make sure the foot petal is snuggly connected into the plug of the machine, and if it is, then the machine needs to be checked
your machine is most likely "gummy". when sewing machines sit the oils get sticky, particularly in entry level machines as they use cheaper oil. there could also be some tangled threads and lint that are adding to the problem. if your machine was shipped or dropped something may have been bent or broken out of alignment. at best, your machien needs a labor intensive process of dissassembly cleaning and re-lubricating. i would there is probably not a quick fix. i would recommend taking it to a sewing machine repair shop. call ahead to make sure they give free estimates. you may have to leave it for a time but if they charge for estimates then they're not a good shop. i am a sewing mechanic of 20 yrs
If it's been sitting unused for a long time, the lubricating oil will have evaporated and turned to varnish. Use only sewing machine oil to lubricate it after carefully cleaning and loosening all the moving parts. Forcing it will break something expensive.
Could be the drive belt from the motor to the machine is too loose, get a new one. Will the machine turn by hand, if not, then there may be something inside jamming it
