Successful conversion to LP, remaining problem is top pilot flames and oven pilot flame way too high.......... oven adjustment thermostat screws are completely tight (clockwise) per video tutorial Thank You
I have this model too and have had to replace two thermocouples because the pilot is so high it frys them. We replaced the whole modulator last time and it still goes out so I have to relight The pilot is at the lowest setting, it's a GE/Hotpoint issue that was not recalled. I do like the hot 125 degree oven for drying sun dried tomatoes and keeping plates warm.
SOURCE: broiler works, oven settings - no flame, no heat.
Hi, it sounds like the oven ignitor might be bad. Remove the floor panel inside the oven and you will see the ignitor attached to the burner assembly. Turn the oven on and see if it glows. You can test the connection for the ignitor and see if it gets 120V to it. The most common problem with the gas oven is the ignitor. Most of the time, the ignitor glows but is not strong enough to open the gas valve.
Please let me know if this was helpfull or if I can assist you further.
Thanks
Vic
SOURCE: ge profile propane conversion burners work fine
The gas regulator should have had the oriface changed in it, the oricafe in the gas valve is different, and the air adjustment where the gas goes into the burn may require adjustment. Contact your propane supplier, they do not want you blown up and may come out and adjust this for free.
