Sony FD Trinitron WEGA KV-32HS500 32" TV Logo
Posted on Mar 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No sound from my Sony KV-32HS500. Muting is off, Speaker option set to ON and MTS function set to stereo, still no sound can be raised at TV control or remote although volume band can be seen increasing and decreasing on screen. Hal
  • loenen Mar 31, 2009
    I have aSony kv-36hs500 that turns on but has no sound at all. occasionally small clicks and pops are heard from speakers but nothing else. also the tv seems to have trouble locking onto tv channels. once locked on the channel stays on screen , occasionally fading in and out. Also the tv does turn on and there is no problem with the crt with brightness, color or tint, etc. It does take time sometimes for the crt to come to life otherwise its fine. I am suspecting a power supply problem for the rest of the system. Any ideas
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 318 Answers
  • Posted on Apr 01, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
318
Questions
0
Helped
86312
Points
527
The audio amplifier is faulty,
the following can be checked, audio amp IC ,
speaker continuity resistance
the output be checked on pins voltages.
I cannot get any sound from my wega KV-24FS120 sony. Sound does not come from TV speakers themselves. I tried MTS and all the audio functions. What to do? Demian
Hi,There are three cause of no sound,ethier the problem is in the speaker,sound driver or output and from the audio setting.First is check the setting, that you already done that what you sad.Now check the speaker if good or not,Use analog or digital tester to check the speaker if good or not or test the speaker to the other amplifier to identify if good or not.If the speaker is deffective replace it and if the speaker is good the problem is in the sound driver.Maybe the sound output ic is deffective or no supply.Thats why it is needed to troubleshoot and repair the sound circuit section of your television.Thanks
Sony FD Trinitron WEGA KV-32HS500 --had the 7 blinks problem, took out D board and resoldered pins--didn't work. But now it blinks 3 times!!\r\n . . .I guess I still have to replace those IC's Anyone have...
On some models 3 blinks pertain to a lamp cover error, lamp cover is not attached securely or lamp is not set securely causing no picture or sound. There are switches or sensors that interlock and send signals to the board telling it is set securely.
I can't access the Audio Out in the menu options. It's currently set to Variable. I hooked up the TV to my stereo with the Red/White RCA cables but get no sound? I am guessing it's due to that menu option.
That means that output varies with with volume control, but you have to set speaker off to activate the audio output, this is done in this same audio menu.
The picture works but the audio sound does not.Could this be due to the set been connected to virgin tv media and the remote has something to do with the problem, is there any manual way to obtain audio on...
first check the speaker setting in the menu see if the speaker is selected ON. if the speaker is on then check the SAP function of the set. check this with the remote with the MTS button on the remote. keep hitting the button untill the word stereo appears.
1helpful
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
1helpful
My sound on the TV just went about a week ago and i cannont get it back for some reason. Everything else is perfect so I dont know what is wrong with it?
Check your TV may be set to Auto SAP in the MTS feature. Make sure the speaker option is set to On in the Audio Menu. Or Reset in Factory setting> Turn on the TV. While holding down the RESET button on the remote control, press the POWER button on the TV front panel.The TV will turn itself off, then back on again. Release the RESET button.
1helpful
My tv wont turn on.it sounds like its going to but
The 7 blinks are an error indication that is generated by protection circuitry inside the set. A problem has been detected and the set is shutdown to prevent further damage. The cilnking is the power relay that is attempting to turn on the set. I'll look up the eror code and update this with the likely solution later today.
Dan
5answers
Sony KV 32HS500
what is the blinking pattern? blink pause blink
Sony Trinitron kv-32hs500
plug out the tv and let it stand for about 2hrs so that it can reset itself if that does not work take the set to a tech for repairs the problem is in the power supply and related circuits good luck.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
